600 fsb and ddr3 2000mhz orthos stable on e8600 q822a435 on rampage
thought i'd see what fsb and ram speed i could get orthos stable on my e8600 Q822A435 on the rampage extreme, stopped it when over an hour (thats enough for me :)), the q822a435 i have loves low volts and is orthos stable at 4360 at 1.272 volt real at a lower fsb and higher multiplier, but mine runs hot for the volts used, the cpu is on watercooling as is the northbridge
Volts used
cpu 1.28 (1.2875 set in bios llc enabled)
northbridge 1.54
vtt 1.40
ram 1.93
cpu pll 1.51 set in bios
http://www.gbwatches.com/pics/600fsbddr32000orthos.jpg
634fsb and ddr3 ram at 2113mhz on rampage extreme with e8600 (q822a435)
i thought i'd see what ramspeed and fsb i could do the everest memory benchmark at , this is using the 400 strap and loose memory subtimings and tref on ram set at 100 and running and on performance level 10 so not mind blowing numbers
Volts used
cpu 1. 392 (1.4 set in bios llc enabled)
northbridge 1.73
vtt 1.40
ram 2.04
upped southbridge voltages to 1.6 (for the 1.5 one) and 1.1 (for the 1.05 one)
http://gbwatches.com/pics/634fsb.jpg
picked up a QHEX Q814A527 !!!!!
hi guys...managed to pick up a an e8600 es off the bay....
hopefully it will be good...does 4.5 stable on air and seen screenies for booting at 5.18ghz...
time will tell...
:up:
cheers for that. ill keep ya posted on how i go...
cheers for the tips.... ill keep you posted
Well boys...think i done good!!!
Originally Posted by
GLENBOY
very nice rabor i am also a q822a435 man
Hey lads...think i managed a good one today.....
picked up a lovely EO E8600 Q822A438 at the first shop i came to....
hopefully a good batch!!!
ill let ya know how i get on...looks like the ES E8600 i got could go on the bay before i even get it...lol
Cheers
Gordy! :)
