last pix
last pix
Nice pics, however I need to know if the MPC-X38 NB block and the Fuzion V2 both fit on the Rampage. Is anybody able to confirm this?
Looks good, can't wait to see results :D
ok here we go YES they do work together clearance is do-able
BUT the 4 holes on the out side of the plexi DO NOT match up with the MoBo
the 2 holes slightly closer to the block DO MATCH UP ! Now if it were me I would drill 2 more holes in da thing just to get a better fit & trim off the EARS where the other holes are
NOW also I do NOT think the Pro mount springs/screws will work
as u can see in pix of the " CyberDruid's backing mod " screws barely miss the plexi & the pro mount screws are spring covered SOO there a chance those will NOT clear the plexi on the DD X38 block without notching the plexi mount
Good to see. Umm, wtf? Screws on the block don't line up properly? Sorry I am not about to take a drill to it. If this is the case, I will have to sell/return it. I will try and contact DangerDen and find out whats up with this, maybe they can fix it for me. If not I'll have to stick with the MPC-Universal, which DOES fit, and works with D-tek pro mount.
mo pix
hope this helps 003
now it looks like the plexi is sitting on those capacitors but really it's all but a C-hair they are below it
But if u tighten down the block = they might/will hit
the plexi can be easy modded to miss those as well
Yeah i'm selling this block of mine
NO WAY am I gonna mod it as i'm going for the clean look on all my builds
tell the truth this is not the 1st time DD has sold me a block they said would fit for sure
& that it only is held by the two holes instead of the four holes is a deal killer also
any way while i'm at it i do pix of the EK blocks as I check clearances tonite !
I know this will help others out there in XS land !
I'd love to find a quality X38/48 NB block that fits the Rampage Formula and uses all four holes...
Thanks for the pics!
here's the EK block ... if it looks off center it slightly is when centered over the MoBo holes but it's a 2 holer also ..but it does cover 95% of the chipset & i like the low profile of the block last shoot shows the other chipset block which fits fine & looks to miss the 2nd Vid card if it's water cooled
any one have these on their board ?? do they(the Barbs) miss the 2nd Vid card as i'm going Crossfire with this rig
while i'm at it here's the test bed with my 2nd R/F & the Q9450
:up: I just ordered an Asus Rampage Formula. It's on the way.
:cool:
Traveler when you get your Rampage formula will you test your Max FSb? most / all of them can do 585+ when tweaked right, and i would like to see what the newer ones can do.
Big slappy u look like some watercoolin god ! where u get all those stuff. like your benchtable :)
Btw: what did u test in your test setup?
@ oo3 looks like after sleeping on it ..I'm gonna Mod the DD block as I put together the Brass plate for the DD & it has a thinner plexi hold down plate that sits on top of the brass top(barbs mount flush on the brass) & I can use the other thick plexi as a drilling guide for the R/F mobo holes into the thinner plexi
the EK block is lacking in a few ways to my liking
1st it just a box no pins inside for better heat transfer ,
2nd i don't like the idea of 2 holes ,
3rd the EK has sliders for the holes making it even less stable
4th the DD block covers the whole chipset as the EK don't
with this mod i gonna do i'll also be able to use the copper backing plate that comes with the Rampage Formula & end up with a very firm,stable & high heat transfer water block
preformance is more important than bling with this chipset
PIX below
I test everything , I get the mobo up running, get it O/C'ed, test memory load O/S , drivers , run bench marks , test games ,test apps ,with the R/F having the power & reset buttons on the mobo it's self. this makes a test bed a very good tool to bullet proof the P/C before it goes into a case, also do the burn in , test the water blocks (test bench has a temp probe ,resevior,fans,psu,Rad & pump)
most all has come from Petra's Tech Shop with help from Quoc he's the best guy ..
the test bed is a modded HSPC test station
here's a link to them
http://www.petrastechshop.com/hstest.html
I don't know if I should post this in this thread or start a new one. I'm about ready to FREAK OUT MAN! I posted earlier about my DDR2 800 Crucial Ballistix not being able to pass Memtest86 http://www.xtremesystems.org/forums/...181921&page=20. I adjusted voltage and timings and even tRFC like suggested. They wouldn't pass. I RMA'd the RAM and the MB and got new of each. It was decided that the 2Gb sticks were not compatible with the Rampage.
I order some G.Skill DDR2 1066. They will not pass Memtest86 either. WTF?
Unfortunately, it's starting to look like the common denominator is me.
Am I running the right program -Memtest86 v3.4? Is it possible that something is wrong with the bootable CD?
Maybe they sent u back the same (broken) board.
What performance level do ya'll run 2x2Gb at? I had it set to auto. Now I'm trying 7. What tRFC?
-Thanks
It's not the same board. It came with all the accesories and another copy of Striker game. I reapplied the heatsink also and the new one is definitely a different board. Or they went through a lot of trouble to trick me.
