so bottom is for gpu and top unit is for the cpu right? are those both bakers blocks! and what r they? top one machII and bottom machI?
Wow,
awesome looking units you have there Hobocrow, must say I'm new to this side of things, but i'd love to learn as much as possible, and give my barton 3000+ a bit of a wind up.
Welcome to Xtreme Freezeman! :D
:toast:
thanks dude
man i've been missing out on all the fun, just spent the last 3 days reading the posts in here and i'm just blown away with the tech knowledge you guys have.
All i can say is i've been on the darker side of the moon for far too long.
I gotta get me one of the prommie mach 2's
Could (any)one of you lads 'tell me which radiator is found in the prommy's??
Or any rad' that does this many passes?
And if i may push my question a little further ;)
Any place i could buy one here in Holland (or in Europe for that matter?)
I'm trying to gather some parts for a WaterCooling-set that would aid my MachI in the struggle for more MegaHurtzzez ;)
And ontopic:
Y'all keep up your Kick-Ass-Modding! :slobber:
Isp and Freezeman..Thanks guys! :)
I've been taking advantage of this unusally warm weather and have been spending time on the boat! I worked on the case mod alittle and have my CoolMaster 201 mounted on top of the MachII now! Still have to modify the Mobo tray I think.
Pimpsho...yes, It's a machI with a Baker18 GPU evap on the bottom and a machII 404 mod with the standard prommie CPU evap on the top.
Wow.. awesome bowman :D :D
I'm also curious where to get a small condensor like a vapo/prommy uses. Preferably in the US or Canada though ;)
I have had a manufacturer prototype several condensers rated for approx 850btuh @ 100 cfm airflow. They are 4" x 6" x about 1.5"? thick.
I've started up my scratch job with a Tecumseh TPA-1410 compressor and WOW! The condenser is excellent! I have received the price breaks on the quantity orders of these condensers from the mfgr.... if I can get an order in for around 75 to 100, I can provide them for about (price edited in order to not SPAM!.. but it's cheap!) I can't find the quote sheet, right away, so don't quote me on that.
BUT... the condenser is PERRRRFECT!
There is a condenser related thread on the forum, with a pic of the custom condensr....
I'll post pics of my new scratch built custom critter... It's HOT!... and my NI-cad wire does a good job on the block, but I needed to hook up to 5V. The 3.3V didn't seem to do the job well during operation.
see ya'
Herefishy,
Speaking of your condensor, YES...it's quite nice.
C
!I learned a lot reading this thread..!
*bowman
Man you sure know your stuff.. Impressive work!!! :-)
*Dude
Looks like its going to be a killer setup
Hey Bowman...........You did good, Buddy!!! :banana: :banana: :banana:
Here'd how the Prometeia Control Center seems my "old 2.8" @210 fsb and no load.... :toast: I've had it over 4Ghz and I'm playing with the mem.
btw, the p4c800e bios says it's -111c @ idle... :D
Divine evil
I'm using a Ford xf falcon 3 core radiator on my water cooling, cheap to pick up at the wreckers and cleaned with new fittings put on it was $30
:soap:
well thank you...been a bad weekend here for me personally,Quote:
but that just makes me smile...thank you for the kind words....:D
Great thread. I read through it all over the course of a couple days. I was pretty lost in the scientific discussion, but the pictures, temps and monster overclocks are something I can understand. :D You do indeed do some awesome work, Bowman. Someday when I go phase change, I hope you're still doing mods.
How much captube was added for Hobocrow´s unit?
Ok!! I promise not to post anymore pics about my Bowman modded M2, well not today anyway....:D :p:
MM........you know that I'm a n00b at this! I thought 34sec was just so so for a 2.8ghz at 4ghz...It's ok isn't it! :)Quote:
Originally posted by MickeyMouse
no post away :) loking good thta has to be a EE chip right for 34s at only 4ghz ;)
Jason, regular P4 can do 34sec at sub 4Ghz (3.2C on P4C800 1:1 got me 34sec at 3980 IIRC) ;)
Macci.......:p: :D
grr just read this thing..... i think i might have to whip out the big bucks to get me a nice bowman modded m2 :p:
I know that this isn't important or news worthy....but , it is too me so I'm going to post it! :D
I know that 30k will probly be broken this weekend and to be on page 1 of the ORB will reguire a score of 26k...I have none of these things....yet! ;)
I'm still learning and testing! I've improved some things!.....:)
Hobocrow,
That's a da*n fine score... I wish I had YOUR cooling!!
C
Thanks, Charlie :) I wish I had YOUR skills!!Quote:
Originally posted by charlie
Hobocrow,
C
Hobocrow man i am so happy about your fun with the modded units.they seam to be doing better than exspected....:D
sorry i havent been posing alot lately,been working on figuring out some benching problems,as i have been benching latley.
and i have finally gotten a good setup.
i dont want to say too much right now.but just check the orb and see how my setup is doing.:D
i will be sending in results all weekend,i hope to get close to the great one..OPP.and OPP thanks for the Card and help.:D
well i just have another way around that car score.i work on the back end first...and OPP's high core card helps me in gpu related tests,the card will run 594 core.and that maxes alot of differanceQuote:
BTW edit just checked the orb, ya still got a low car low score, but
congrat's on 27.5k :) you deseve it :)
and i havent even maxed the cpu,and OPP's card still has some more in it:D
i will maybe tonight get back to it.until i get a pci bus card i cannt get above 285 without hard drive corruption.
i may see if i can get one run done at 285 even if it takes out the hd.:D
car low does bug me,but i will keep at it until i get me a good run.
