Looks nice! Not to much bling bling :D
looks nice, and apparently doesn't effect your ability to go back to #1 on the bot after a few hours :rofl:
Hey vince are your TR1 GTR's still alive and kicking or you just using them for a prop? Mine seem to freak out on ln2 on asus :/, seems its an asus issue they are fine on giga with ln2 and rock out in asus with any cooling besides ln2.
ROFL at supernova. LOL
Glad to see we have our 1st Alu F1? :D ?
now how's about some diamond / gold plating ?
does nickel plating affect pot's performance?
how about making one from silver? :D
i say yes and no :D.
no need to make it shine and bling like that, becaus there's gone be insulation over it :D.
if ur tube is brown it means u used it good ;).
Interesting path Vince, sounds absolutely stellar about the hold up 2+ months
Futhermore when it comes to overclocking it comes down to the smallest, so coating it preventing dirt build up is a top nice idea
the SICK look is a sideway bonus , but as Vince says #1 is performance
Vince does this amazing new pot have a name yet:party3:
How pretty
:D
DRAGON F1 with nickel plate.....
Thanks Vince.......:up:
http://img254.imageshack.us/img254/6521/img0391r.jpg
http://img137.imageshack.us/img137/3861/img0392y.jpg
http://img255.imageshack.us/img255/9979/img0393y.jpg
http://img696.imageshack.us/img696/2230/img0395h.jpg
http://img684.imageshack.us/img684/2501/img0401.jpg
http://img693.imageshack.us/img693/2165/img0404.jpg
http://img255.imageshack.us/img255/6373/img0405y.jpg
Theres no more that sexy tube box? :)
Thank you sir!
I received the box several days ago, I appreciate all the extra foam and materials you threw in!
I'm still gathering materials for first DICE run, will post updates and pictures in the next couple of days.
As a hardcore Tolkien fan.. I couldn't resist :D
"The Block of Isengard" :hrhr::devil:
http://i34.tinypic.com/2w5u9ky.jpg
Looking shiny :D
Did some lapping on it -
BEFORE -
http://i38.tinypic.com/1gom03.jpg
AFTER -
http://i36.tinypic.com/demxir.jpg
Experimented a bit with multiple layers.. till this:
http://i34.tinypic.com/2m7yjvq.jpg
poured some 100% acetone, some DICE in and tested it on the shelf.
http://i33.tinypic.com/2mnrcp3.jpg
http://i37.tinypic.com/2zftx8h.jpg
After I finished and stripped down everything to clean, the pot remained 'frozen' for over 40 minutes. incredible design & quality.
How much Alcohol do I need to pour in to make the cooling the most effective?
up to the level of the drills?
halfway?
I know it's probably nothing (comparing to the hardcore oc'ers here), but here is my personal record:
http://i38.tinypic.com/2dv1s1t.png
CPU-Z Validator 3.1
Will work on forward to reach 5.2
GREAT pot.
Is that on dice or ln2?
Either way, nice run!
That is on DICE :)
I have managed to update my score to http://valid.canardpc.com/cache/banner/833489.png.
Super PI 32:
http://i48.tinypic.com/qn9v1l.png
Pi8M:
http://i49.tinypic.com/otjif5.png
PI1M:
http://i50.tinypic.com/11ab9g4.png
WPRIME 32:
http://i48.tinypic.com/35irdb4.png
WPRIMW 1024:
http://hwbot.org/result.do?resultId=922011
http://i48.tinypic.com/11m9tlc.png
:ocau:
Not bad for a Core i7 920, you need to get yourself a w3570 to really push that pot and board though :p: Best to wait for Gulftown though, no sense buying obsolete chips.
Nice work and thank you so much for your kind words!!! :D
For better DI performance on the F1, try crushing all of your dry ice into "powdery snow" first by putting the pellets in abag and smashing with a hammer or something. Then, maybe about enough acetone to fill all the pits and keep the snow in the unit packed and "tamped" down and you will get your best performance. Sometimes, I used to even put a very heavy weight into the pot to put pressure down on the inside of the base on the DI/acetone snow/slush mixture and keeping airspace minimized in the mix.
