Thanks Ace;) , i try to put some air in that zone or remove the heatsink an put some fresh as5 to improve the contact.
Ace, im 400x8 now at stock board volts, whats your mobo volts to 450 fsb?
Make sure the stock heatsinc is actually touching the pwms. I took mine off and it was only touching about a third of them. I cut up a HDD cooler and put that on there and I see 36c idle and 38c to 40c load at 1.55vcore. With higher vcore it goes up from there where I ahve scene 53c before.
my vcore is between 1.53-1.55...
my room temp is 77F....AC
:eek: 36š idle and 40š load, this temps are much better. I donīt understand why abit donīt improve this little things. With a good contact heat-pipes this board are very cool compare with other p35īs.
Ace, 1,55v mch to 450?
Well this one I set up the phase on it before I even fired it up so I was hoping for the best. I kept the stock cooler intact so I could put it back on but I had a extreme spirit II that I put on the NB and modified my cooler for the pwm. Luckily it works like a charm. Great ocing mobo, cant wait to get a cpu that doesnt have a fsb wall at 540mhz to see how high I can get the fsb.
have you tried to uninstall and then re-install Uguru
What are ppl using to take a screen shot of uGuru ??
I have tried irfanview which works for everything except uGuru ????
No need for ALT. Just PrtScn, then open PAINT and EDIT/PASTE...FILE/SAVE. I also enjoy MWSnap...very light application. Works with all versions of windows.
@Ace-a-Rue & Turbodream : maybe you can try this.....:) :)
set lower tranparency setting on UGURU and restart.....I try this worked and still Ok...... I use Ati Card
http://img.techpowerup.org/070717/uguru.jpg
and when I Use Oc with Uguru and set PCI E 107 worked normaly.....no problem :) :)
http://img.techpowerup.org/070717/uguru 2.jpg
You must be pumping north of 1.5V with 3.62GHz. What's your peak Orthos/TAT/S&M temp? Do you have an L2 revision chip with 100C Tjunction?
My E4300 is semi-stable at 3.6GHz with 1.505Vcore and Big Typhoon/120 x 38mm Panaflo medium speed. Semi because I don't dare run TAT during the summer heat...80C within 30 seconds of test. Yes, the heat spreader has been lapped (top and bottom). I gained about 8C after re-mounting the heat spreader because of poor contact between it and the CPU core.
@furballi : I dont tell about OC performance but Screen UGURU on ATI Card :) :)
My Uguru works now, changed skin so now i can OC again :)
Serious question: I plan on getting q6600 and ds3r and I've heard good things about its OC abilities. Since I dont need SLI, should I stick with the p35-ds3r or get the IP35-pro?? :shrug: Its seems to me both boards are pulling off similar FSB.
does giga have something similar to Abit's Uguru?
What's so special about Uguru :confused:
you change FSB, PCIe bus speed and all voltages that count for overclocking right from windows...the only thing you can't do is change memory straps and multipliers...memory straps need a re-boot to accomplish a change in configuration!
this is what you can change from windows:
