Are you using x1900 x-fire Raju ?
yes with catalyst 6.10...
430 fsb with 1.61 vcore is no go for 3d mark 2006 (the pc resets just after canyon flight). 420fsb is fine for 3dmark06 with vdimm at 2.25...
430fsb Battlefield crashes back to desktop before the ea logo even comes on.
I'm just experimenting with 420fsb......
will let you know...
regards
Raja
i hope soon is very very soon :)Quote:
Originally Posted by hipro5
I'm just saying that anyone can correctly say, with no fear of contradiction, that their computer is stable if it works properly...even if all they do isQuote:
Originally Posted by raju
boot into windows and move their cursor around. It is stable by definition.
Originally Posted by roller11
that was never in dispute.... 'horses for courses'
I doubt there was anyone that confused, though there is always the possibilty..
The issue of concern is Orthos stability, I guess that much is clear..
My question is if I were to get a e6600 and not plan to us a lower multi will I still get a close OC (~3.2-3.5 on air) compared to a P5B-dx. I am not looking for the highest FSB, just an equal OC potential over the P5B-dx.
i've tried to get a sample via TD and Abit and no one is willing to supply a sample. i had the same issues with gigabyte as i wanted to pit my DS3 against the DQ6.
frankly right now im booting into windows at 450x9 from the bios but she dont last long and thats @ 1.6v bios 1.63v via DMM and i cant run anything in windows to check as it usually locks up.
i am also booting at 500x7 too but it wont boot into windows as the DS3 has that ungodly pathetic Micron D9 issue and will not run the gskill HZ 6400 past 950 mhz no matter what i do. so i cant test it very well since i always have to run a 1:1 ratio. i have tried others but it doesnt matter, even dropping the fsb to 100mhz and cranking the dram multi to 4.00 and then rasing the fsb from there it doesnt work..
anywho,, i'm going to keep trying to get sample board for both the biostar and abit but i doubt i will get anywhere. techdata isnt known for being worth a crap when it comes to things like that.
but i was looking into the abit, though i dont care for the 1 pci slot i can live with it as i just need it for my audigy 2 ZS and 1 pci-e 1x slot for my Sil 3132 card, and of course only 1 video slot for me.
but what i need is a board that can max my cpu and ram both, very little droop, on the vcore, vdimm and mch yet have enough adjustments in those three settings to really make her scream.
im typically running 3.8ghz 24/7 and its fine and dandy and i cant complain one single bit but the ram 1:1 at that low of a fsb slows things down a tad, nothing you can see or feel in windows but benchmarks to reflect the change.
thanks for the info raju, its nice to see calm educated posts in comparison to my enraged blabbering hehehe.
hipro5:is the vcore set so high in BIOS or you v-modded it?
I would like to know if the new bios will allow vcore above 1.7 (real),1.8v at least...?
I am now past my 460FSB limit with the new bios, just cannot say how far. ;)Quote:
Originally Posted by Patuga
Bios 1.2 and later: When you pick max 1.725V, it's 1.698V real and ROCK STABLE.....;)Quote:
Originally Posted by mykeos
Only the first bios had a problem....When - for example - you picked 1.6V, in real was 1.5V.......
....and yes VCore Moded - ALWAYS - ....:D
You're teasing me so as to take off my Fatbodies right?.....:DQuote:
Originally Posted by bingo13
I'll slot in the CellShock ones and test tomorrow.....;)
Hipro, could you release a photo of the vcore mod for those of us who are electronically challenged?
I'll upload a FULL Mod guide in a few days for it....;)Quote:
Originally Posted by sadcat1
Thank you
how about full bios settings too? Though there isn't much to show.
You know what George, the Asus pro is back up and running... Did a bit of testing to see what had gone down, bypassed no issues...
Works fine with the maximiser controlling ram and vtt!! Will bench asap....
regards
Raja
well i never like to push my cpu to high clockspeed but only stable PI 1m.Quote:
In my experience dual PI 32m is nowhere near 24/7 stable since i had 5 c2d processors that can easily passed dual PI 32m but in the end failed orthos or dual sp2004 after just 10secs.
So for me daily stable means I am able to to run at least 8 hrs of orthos / dual sp2004 in any tests (large fft, small fft, blend test, or custom) but normally i let them ran for at least 12 hrs.
and my current E6400 can do 3.2ghz @ stock vcore, 3.3ghz @ 1.35vcore, and 3.44ghz @ 1.375vcore. Never try higher since I dont want my cpu to hit more than 60C during load (coretemp)
I hope Abit can help me at least 3.2ghz stable orthos @ stock vcore.. I dun care bout higher clockspeed, coz 3.2ghz is very fast already :D
Originally Posted by Lestat
I'm just a humble overclocker like you my friend, we need all types to make up a forum, that's the beauty of individuality. On topic though, I guess we needed a fresh perspective here and to look at the fact that different people deserve their criteria to be put forwards too without being burnt down everytime. That will help make XS the place it should truly be...
I won't complete judgement on the board until we can get hold of the new bios and assess what needs to be done after that. Then I will confirm my findings with you guys here and some of my trusted friends:clap: to make sure that I am not wrong or brash about anything I say...
regards
Raja
Originally Posted by irenic
well you are not alone and there are many here it seems like you, myself included. 3.2ghz will be no sweat with an e6600, unless it's the worlds worst e6600, which I doubt...
regards
Raja
Whats the max vcore you'd put through a core 2 duo for 24/7 use without cuttings it's life span down to under 1 year. What would be max temps to run at with said vcore under good quality air cooling.
Thanks.
Wonder if this new BIOS has fixed some RAM setting issues (manual mode is unstable occasionally, must use By SPD instead)?
If i use Uguru in windows, i get a very big drop. 1.5 goes to 1.43 and 1.65 to get 1.58Vcore, of course in full load it only goes 1.5~1.56 ;)Quote:
Does the program detect the settings in the bios? and also, what about the pci-e clock? is it locked @ 100? cause i tried to change it in windows to 101 only to make my computer lock
I can't seem to get an answer on pcie clock, in the release bios, it was in the bios and you could adjust it to what ever you wanted and with the new bios you only find it in guru panel and yes it locks windows:fact:Quote:
Uguru works fine BUT it STILL shows inaccurate VCore.....Just "shows".....Whatever you pick within bios, that's it.....;)Quote:
As for PCI-E and PCI frequencies, yes they are locked at 100MHz and 33.3MHz......EVEN at higher frequencies when you pick them from Uguru, are locked too +/-....;)
http://www.thelab.gr/images/Hipro5/A...26MHz_bios.jpg
http://www.thelab.gr/images/Hipro5/A...32MHz_bios.jpg
Hmmm......did you unsolder anything?....:)Quote:
no I did not have to, sorted via pm anyway....
regards
Raja
Will continue testing with the ABit this week, then move back over to the Asus over next weekend...
