You can try taking a look here:
http://www.thetechrepository.com/showthread.php?t=41
I've personally been able to do 400fsb relatively easily on my p5b vanilla. However on my friend's p5b dlx, with older c1 chip, it was a little harder.
Make sure you have spread spectrum turned off. Try pcie of 100, 105, and 110, instead of just 101.
See if it helps to manually define the other voltages. 1.057vich should be fine, along with 1.5vsb, but if you want, you can try bumping them each a notch.
Honestly, I've found c1e/speedstep/vanderpool to have no real effect at all, but it may for you so it's worth a shot.
Also, what bios are you running? Try updating to the latest if you're using an old version.
Can you try 400x7? How about 400x9 just to see if it'll post? How is your cooling for the northbridge?
