http://www.abload.de/img/hr02_029vw4.jpg
http://www.abload.de/img/hr_02auto2.jpg
Here's my 700D:
http://i619.photobucket.com/albums/t...cius/inner.jpg
Lol wtf :D
Ramiro - Boy are you creative! That's pretty extreme air cooling on a vid card.
now put that thing on a case!!! :up::up:
Ahh zipties are awesome :yepp:
contribution;
http://imgur.com/eYRYN.jpg
http://imgur.com/YQ5bY.jpg
http://imgur.com/yfNgs.jpg
http://i.imgur.com/7jc1f.jpg
looking great ;)
Nice setup :rolleyes:
That isn't a rolling eye smilie. That's a lookin-up-with-admiration smilie, or so I interpret it.
here is my rig
by the way its a little bright
I like the way you did the GPU wiring...
Sweet build! I really like the case. What kind is it? HAF?
CM HAF X ^ (aka HAF 942)
its the haf x like ScottALot said
i have had the haf 932 and to be honnest the haf-x is fantastic so much space and better looking to me becuse it comes already black inside it also has filters everyware what the 932 did not have (i recomed this case to anyone)
Andrea deluxe (appologise for long post)
what mobo are you using and cpu do you have and oc your running
its just i have the gigabite ud5 (i think the one you have) and i was wondering what scaling your getting with tri-sli
i have been considering getting another gtx 470 but dont reall know if its worth it plus i might have to upgrade my psu dont think my coolermaster silent pro 850watt will cut it since my i7 920 is at 3.8ghz
i dont know what do you think?
sweet rig by the way and i wold recomend getiing a 3wat sli brige that is black it will look sicker than it alreaddy is if you can ge them i think evga are black
ps if you can can you turn (off) phyx and run 3d mark vantage and let me know what you getting for cpu and gpu points please if you can i know the cpu score goes thue the roof it physx is on abd is not a reliable score to me
the one thing wold have changed on the haf-x is to have a secont psu fitting at the top of the case like the 932 but i have to say i prefer the looks on the top of the haf-x becuse it hides the fans if your looking down at the case
if you know what i meen
if i was any good at painting a case i wold have done the same and saved the money but im rubbish at it lol
im still thinking of ways to make my case more neat it still seems a little messy to me :)
