The Seasonic 550 will do fine for the rig on your sig. It is fully modular and the efficiency is unbeatable. :)
I just switched from the semi-modular Antec Truepower New Blue 750 (had to rma) to the fully modular Seasonic X-650.
I highly recommend that whatever psu you get, make sure it's fully modular. I have seen no semi-modular psu where the manufacturer permanently connects only the ATX-24 and the 4+4 mb 12v power connector. They all throw in something you end up tucking away. I love having only the cables I want.
Yeup, also when you sleeve the cables, there will be no risk of frying up your power supply. :)
Nice pics and config :yepp:
What coolers are? Enermax Magma?
Thanks Malik, i'm using stock fans on Thermaltake Frio but i'm thinking to change for those magma :inlove:
http://i817.photobucket.com/albums/z...l/Img_9952.jpg
http://i817.photobucket.com/albums/z...l/Img_9953.jpg
http://i817.photobucket.com/albums/z...l/Img_9964.jpg
http://i817.photobucket.com/albums/z...l/Img_9966.jpg
http://i817.photobucket.com/albums/z...l/Img_9962.jpg
http://i817.photobucket.com/albums/z...l/Img_9963.jpg
http://i817.photobucket.com/albums/z...l/Img_9967.jpg
http://i817.photobucket.com/albums/z...l/Img_9968.jpg
Last pic is cool, GT blades look see thru :)
Unrealer I've been hitting your rig pictures ever since I signed up on this forum. They are simply AWESOME! :up:
Thanks =) :up:
First chapter of the painting:
http://img338.imageshack.us/img338/6760/ee1b.jpg
http://img641.imageshack.us/img641/8560/ee2d.jpg
http://img839.imageshack.us/img839/4214/ee3i.jpg
http://img814.imageshack.us/img814/9200/ee4.jpg
http://img34.imageshack.us/img34/7970/ee5zg.jpg
http://img138.imageshack.us/img138/4600/ee6x.jpg
http://img5.imageshack.us/img5/5592/ee7q.jpg
http://img716.imageshack.us/img716/7450/ee8v.jpg
I'd love to see a black frame and red fan on the GT.
http://www.xtremesystems.org/forums/...&postcount=589
Shazza did it on her Worklog.
ugh... UNHHH... oh yeaaah! I have got to get me some of them Red GTs! They make me slap myself:
http://farm5.static.flickr.com/4140/...43c021e410.jpg
If Shazza was my grammy, I'd rap like this: http://www.youtube.com/watch?v=HVEe7TrUabg
Re-did the layout for my pc.
http://i87.photobucket.com/albums/k1...y/IMG_0083.jpg
http://i87.photobucket.com/albums/k1...y/IMG_0150.jpg
SteelSeries headphones, correct?
I know about that, therefore I tried to find the problem, and found 3 foundamental issues:
-controller can't power up 12v on TEC
-there's bad thermal compound on coldplate that connect heatsink with TEC
and there's an issue that IMHO is the main problem on it:
-heatpipes aren't between two plates that can immediately moderate the heat of CPU, so gas or liquid into the heatpipes boiling with too violence and the cold that arrives by TEC can't dissipate directly that heat, therefore is created two distinct areas:
-TEC with his heatsink
-CPU direct heatsink
the result:
truly bad performances
where's solution?
put on heatpipes an heatsink that can dissipate immediately the heat of CPU and at the same time TEC that dissipate the rest of heat and make necessary cold too maintain the better condition to dissipate heat:up:
http://www.abload.de/img/img_7799tnec.jpg
...waiting for MORA 3 Pro 18x140mm Biiiig Monster Rad :D
