*bashes head repeatedly* I HATE THIS BIOS!!!! It's so frickin crap! Tried ll sorts of straps and voltages and it just goes "DET RAM" - the only 1 I can get to work and it's also 100% stress stable is this
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 10.0
FSB Frequency : 400
FSB Strap to North Bridge : 266
PCI-E Frequency: 100
DRAM Frequency: 1203
Everything else : Auto
CPU Voltage : 1.2365 (I think that's right)
CPU PLL Voltage : Auto
North Bridge Voltage : Auto
DRAM Voltage : Auto
FSB Termination Voltage : Auto
South Bridge Voltage : Auto
South Bridge 1.5v Voltage: Auto
Loadline Calibration : Enable
CPU GTL Reference : Auto
North Bridge GTL Reference : Auto
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : Auto
SB 1.5V Voltage : Auto
As soon as I touch anything else it hates me. I did at 1 point get the 1st memory option running (I'm using the 2nd option) but I needed to set the ram manually (even though it's the exact same settings as they are automaticaly) and set the ram voltages to something like 2.2v and even then although it got past without DET RAM error, it wouldn't boot, just blue screened. Went backa nd tweaked the rest againa nd again and again but nope, not a single boot out of any of it. :'(
This other thing that concerns me is that I've suddenly got an even bigger v-droop. I put 1.23... v for CPU and it's running 1.92v - it was the 1 below that I'm sure but if I use that it now says 1.16v :(
Any ideas?
~Bex
