1 Attachment(s)
Vcore Measuring Point On The Ip35
here it is...see the green arrow pointing at the resistor with a whote box around it....that end of the resistor you should put your positive probe on...you can clip the negative onto the spring tension of the PS2 port or to one of your heatpipes on your cpu heatsink.
EDIT:...be careful with the probe as to not touch anything else (electrical parts) while measuring...i recommend that you tape your probe with electrical tape leaving only a 1/8 to 1/4 inch of the probe tip exposed so to avoid shorting the resistor out...this will keep the accidental killing the board to just about zero.
