Added some coils :D
http://img.photobucket.com/albums/v3.../waterloop.jpg
http://img.photobucket.com/albums/v3...sj/Radzips.jpg
Thats a nice red bundymania almost the same as mine! but mines red tubing.
tonight I put some....err (I don't know the name of this in your lang. :D ) Put it:
http://www.acmebrinquedos.com.br/loj...rca_texto2.jpg
In my loop, I think it's a lot better :)
Before:
http://img242.imageshack.us/img242/16/dsc09054ti9.jpg
After:
http://img209.imageshack.us/img209/7986/dsc09077br2.jpg
Another pic
Before:
http://img256.imageshack.us/img256/2705/dsc09065kw5.jpg
After:
http://img209.imageshack.us/img209/7615/dsc09079rm0.jpg
What the name of that thing? :confused:
Get better huh?
Rbs.
:wave:
UV dye? Looks nice!
sassa, this is what we call "jeitinho brasileiro".
I cant believe you did that.
Let's wait for some tubing stains or best cheap mod of the year.
hahaha good old Harry Potter Highlighter... looks way better now after you did that :D
Where are your UV lights? :confused:
Looks good, i did this before.. only works with yellow/green highlighter though :( blue didn't work.
A highlighter is just a cloth tube soaked in dye, so ya works a charm. nice effect, lets hope it doesn't have any adverse effect..
I wonder if red will :o
I used to have pink UV marker stuff in my loop. That was 5 years ago. I can tell you, your loop is garbage within 2 months.
Let this be an warning!
yep that might be a big failure dude
I use also txtliner to colorfull coolant but after couple of weeks tubes was darker and color was darker :(
btw First post xD
Yeap right Arni. Don't use it. rbsmontemor if u want have intensive color use dye like Feser View Active UV Dye.
I'll wait and see what happens...in the worst case I'll have to buy new tubing..
I'll let you know if anything bad happens :)
Rbs.
:wave:
After I finished the UV blue project, i realized i don't like it...
So, I'm going easy over to black&white, LED's in fans will be changed as soon as I manage into white, so will come white neon lights...
This is present situation.
CPU-mirror finish:
http://www.imagesforme.com/out.php/i16880_DSC02404.JPG
Cable management under MBO:
http://www.imagesforme.com/out.php/i16881_DSC02408.JPG
Mainboard in place:
http://www.imagesforme.com/out.php/i16882_DSC02412.JPG
Front triple (TT) rad chilled with 5 (!!!) fans, 2 of them PAPST from an old IBM server ("tornado papst")
http://www.imagesforme.com/out.php/i16884_DSC01913.JPG
And my room:)
http://www.imagesforme.com/out.php/i16879_DSC02180.JPG
Liquid is distiled water with anti corro fluid and black ink.
Man I hate those front panel connector cables...
De5tr0yer your HDD screaming : My CAPITAL ! Change HDD place... But everything else is OK ;)
