Sounds like that could be down sized nicely into a mATX box.....
Nah, Hobbit. That room for expansion. :D
Besides it looks like it is running almost passive. Probably pretty quiet.
ain't that hard to sleeve cables, but you gatta take time to do it right!
i suggest you exercise your skill on other cables first, then get to the real stuff... seams a waste of time (and money?!) but it really ain't if you're looking for a good result!
Thought that was part of the definition for bling!! :up:
Ogge_swe, is that case natual metal stock or something you've done?? I like the idea of the inverted mobo tray as the bling of gpu coolers can be seen. However I've read where heatpipe designed NB and MOSFET coolers does not like it. Nice work BTW. :clap:
Would like to see that! :up:
Just finish.:)
http://img84.imageshack.us/img84/427...2010148.th.jpg
Next step, water.
NOFEAR921 nicely done and clean layout! ;)
NOFEAR921 you may not need that fingerguard. Every little bit of air helps.
Im looking for some new case fans, can anyone spot me the link to the huge fan reviews? I see Vapors but that one seems pretty outdated...
Ahh yes thats the one I was looking for, thanks :D
what cooler is that ???
