OMFG... I can't believe people are having problems getting conductive paint or soldering a little wire (its soo easy and YES you can remove after soldering).
LISTEN CAREFULLY: Even easier than the conductive-pen mod!!
1. Get some tape... clear or masking or whatever. Apply around the two points, but not on them.
2. Get ALUMINUM foil.. straight from the kitchen.. that's right.. cut a little piece, and roll up as a wire.
3. Apply aluminum foil between two contacts.. because you masked out everything else there should be no danger in getting a short.. put some more tape over to hold everything.. YOU'RE DONE.
And you didn't need a WIRE (that everybody seems so afraid of) or conductive-pen (which everybody is so confused about)
Since how hard can it possible
