My last card on the list is my x1900xt card, not xtx..
Got my X1950XTX today, Ati Tool 0.26 works fine.
GPU watercooled ~ no mods.. (yet)
vgpu 1.5V @ at least 725MHz (I've to test more)
mvddc 2.083 stock
mvddq 2.080 stock
vddci 1.58V
EDIT:
vGPU 1.575V ~ 796-803MHz is maximum with +15C water... http://www.xtremesystems.org/forums/...lies/crash.gif
Tests just freeze, don't go more.
I need some vGPU & IGPU-mods..uh.
Need AtiTools for vista now! :)
PowerColor (same as bbati) x1900xtx:
662/824 on 1.2v gpu ad 2.0861 memory on water ~44c load
No, you read that right 660 core, 820 memory on 2D volts :eek:
Hi,i have problem with 1950XTX CF,not every time the CF is on... i chek everything on the machine is ok...atitool catch(and clocks) two cards but in 3D work only one card:mad:
install stock drivers (7.1) dont use ati tray tools or atitool, dont disable the hotkey pollar service, and make sure CROSSfire is checked in CCCQuote:
Originally Posted by FireLight
Originally Posted by KoHaN69
It work for now...but the cable who connect two cards maybe not work correctly,in 3dmark 05 and 06 system is restarting of one precisely place ,even when i start only this test(canyon flight).
If the cable is not correctly connected, you should have no crossfire at all, so I dont think that is causing the issueQuote:
today i discover very strange thing..when i shut down my pc and turn on bios is reset:confused: something is wrong, but i cannot understand what:mad:
howsoever two cards is clocking very well,700/2200 with stock cooler and the temp is 60-65c on beching:)
Flashin X1900XT Saphire 512Mb CrossFire
Ok i have downloaded my Bios file here
http://www.techpowerup.com/bios/
I have flashed it and all is ok as its exactly the same as my original so im ok there.
What im stuck with is how to increase the Clocks for 3D Mode?
I increase the clocks using ATi Radeon BIOS Tuner (RaBiT) 2.0a but its only for 2D mode?
This is a noob question i know and i cant find the answer :cool:
Use RaBiT 2.2.1 and you can change 2D and 3D clocks and voltages
I Need Help, :(
I flashed my X1900XT Saphire CF 512mb edition.
To a X1900XTX and its messed things up seriously.
The system still boots and goes into windows Safe Mode. It will crash in normal Windows Boot.
The problem is that when i try to reflash to my older Bios it wont let me, This is using ATIWINFLASH
It says "Critical File Missing. Please Download and run video bios flash files again."
I tryed using Flash tool in dos and it gives a error.
Any Advice..
Hi guys,
I am using Rabit 2.2.1 to edit my bios file.
What are the lowest, working voltages for my X1900XTX?
I currently have set it to:
2D: 1.1v - 405 mhz (core) / 405 mhz (mem)
2D overdrive: 1.1 - 405 mhz (core) / 405 mhz (mem) / T max: 120
3D overdrive: 1.35v - 641 mhz (core) / 765 mhz (mem) / T max 120
Are these values safe? Or can they be lower without thrashing my card?
Let me know, thanks.
HHawk- dont mess with your bios, just use ati tray tools 2d/3d auto overclocking profile
the values vary from card to card, test yours first. and u only specified one voltage there are 3 voltages you can regulate.
What program to use for Ati overclokcing and overvolting under Vista 64 bit?
atitool
www.techpowerup.com
Half of the time I get the message 'kernel mode driver not loaded' or something to that extent. Only a reinstall fixes this, sometimes only with driver reinstallation. Version 0.26 / 0.27 beta
Plus it seems to have difficulty with 2d / 3d mode switching. If I set a given overclock it resets to default 3d at the next 3dmark test. 2d clocks are set on startup of Atitool, loading 3d clocks (artefact scanner for example) on desktop results in immediate crash as the voltage doesnt come up automatically. It just sits there at 1.2v... I thought when starting Atitool 3d clocks were always loaded?
I also get a message that the ati services are disabled, which would explain this 2d / 3d problem but no such thing as 'ati services' is to be found in the available services under administrative tools > services and nothing Ati related is disabled.
Damn I need to get this working as Im getting this 1950 onw ater this week. I need auto overvolt and overclock when loading 3d apps.
Thanks for any and all help.
hy, i not see information :confused: of V-mod cards 1900xt\xtx(i have 1900xt) 1.57v it is very small:( . anybody dying v-mod on this card? mi very need:) .
sory my English:rolleyes:
Sapphire x1950XT 256mb with VF900
688/1026 1.375/2.184/2.184/
This is for 24/7 :)
Moonman VEry BiG thank
Hey guys! Good guide!
Here is my Aircooled (for now) Sapphire X1900XTX R580 with the 1st revision jet-engine 2-slot cooler. Using GPGPU.
I am completing one WU-part (25,000,000 total WU size) every ~24 minutes at 3D clocks 650MHz Core / 1500MHz Mem
http://www.aww-kittah-aww.com/up/fil.../sx1900xtx.PNG
on my previous system
Opty 165cd @ 2.8x ghz dfi ultra d
i had a 1900xtx running 780/850
I got it up to 800mhz on the core ^^ and 860 on the mem
http://www.hardforum.com/showthread.php?t=1033173
there are pics and details
13,767 3dmark 2k5
I believe I maxed out at 6,900 in 2k6
there is also a link to this thread in that one lol
