this is approx how my card clock 605/610 - 610/620Quote:
The score or the VGPU?Quote:
Originally Posted by Supertim0r
The memory is not modded yet, and i have no intention of doing so either :P
it will do 615 MHz unmodded, but i clocked it lower in case the core would conk out first. Does the VDDQ mod help?
http://service.futuremark.com/compare?3dm05=1405611
http://service.futuremark.com/compare?2k1=8779816
here my 1rst result with this card, it is not the best but is it ok?
stock cooling
kitt- gto2 or c3d gto?
its great -gto2 or gto?Quote:
Originally Posted by rookiekiller
people, when posting results PLEASE specify if you have a sapphire gto2 or connect3d gto or sometihng else
THANK YOU
yes it helped my mem clock but I need other cooling than stock :)Quote:
should give it like 2.35/2.3 with ViperJohn ramsink when the arrive (tomorow maybe :eek:)
@kohan69, sorry, its gto2 sapphire
plz help me, i get error msg in aqua3, how can i solve it
http://img429.imageshack.us/my.php?image=aqua2hg.jpg
LOL sorry, no need to shout :p: (look at my sig :fact: :slap: ;) )Quote:
Originally Posted by KoHaN69
Sapphire X800GTO2 with VGPU mod at 1.48v on stock cooling. memory unmodded.
Slightly better score now:
http://service.futuremark.com/compare?3dm05=1409606
at 615/615 MHz
no results yet with the C3D X800GTO !!!!
patience grasshopper...my gto will be arriving shortly :)
Originally Posted by SaFrOuT
my results:
:fact:
http://www.xtremesystems.org/forums/...30#post1110030
:slap:
isnt 1.48 a bit much on stock cooler? is that 1.48 load or does it droop to 1.46 load? what temps you gettingQuote:
I will be posting my results with the C3D X800GTO tommorow..
Will run stock, 100%fan, and Watercooled. Will do Watercooled with vmods in a few days after I am assured the card is in working order.
Originally Posted by MaxxxRacer
Please Please Please do it as soon as u can cuase i will order this card in the next 48 hours and i want to be sure that it can run the speesds of X850XT with stock cooling 24/7 without artifacts or the risk breaking the card
^^I can :)
I ran run X850XTPE Core and X850XT ram :D
Stock cooling w/Vantec Copper Ramsinks
1.48 V loaded. Fully loaded temps 63*C on stock cooler :DQuote:
Originally Posted by pancake
Guys!
Please someone post pics of your card based on R480 in high resolution.
face & back.
I need it !!!!
Please help!
Here is the backQuote:
Originally Posted by xooler
http://www.xtremesystems.org/forums/...22#post1121022
Originally Posted by NickS
which card do u have and which bios r u using, beside any volt mods made or all @ stock volts
w00t!! Just broke 7k!! :banana: :banana: :banana:
it may not be xtreme, but it means a lot to me :fact:
http://service.futuremark.com/compare?3dm05=1412533
Was done at 1.58 volts using ghetto-modded stock cooling:
http://img.photobucket.com/albums/v6...9/PB060113.jpg
:D
Full load temps 67*C
:woot:
KITT why dont you just install some VF700CU ?
nice job mate ! :clap:Quote:
I got my ViperJohn cooling this morning :) I'll let you know my new score when it's installed. Your card perform better than mine with high temp :eek:
supertimor : pics!!
kitt- is that just the regular sh1tsink with a 120mm? -_-
no, extra 80mm fan :D :p:Quote:
