yah i game. I'm in alpha twl RTCW enemy territory league :)Quote:
Go and lie down again for a while :)Quote:
Originally Posted by chew*
You really do know that you should :slapass:
I'm going water soon......here's a preview....Freezer64 suicide shot :eek: :eek: :eek: :eek:
http://img74.imageshack.us/img74/1380/dsc018460lw.jpg
http://img74.imageshack.us/img74/5268/dsc018472vl.jpg
:slobber: http://img215.imageshack.us/img215/3562/dsc018521ks.jpg
Cool. Unfortunately i should be running at those speeds to but instead of buying an Air conditioner this year i bought a chiller 6 months ago that i still don't have.............http://www.xtremesystems.org/forums/...chmentid=13257
If this is accurate info then we should see an new bios giving users somewhat of an edge when using these.Quote:
Originally Posted by bigtoe
http://www.newegg.com/Product/Produc...82E16820227208
hmm should i hit the button or buy some gskill 2x512mb f1 le pc 4400.....
Hmmm is it me or did bios 14 just like dissapear off the abit site...... in fact when i looked up the bios for an8-sli all they offer is 15 and no prereleased bioses. so i checked out the an8 fatality and it jumps from bios 13 to 15 .....I might take a chance on 15 possibly windows xp/64 bit xp problems and maybe if im lucky it wont effect win 2k? Hmm tictac you working on anything?need a beta tester?
BTW The reason im ready to upgrade bios is due to something im going to call the 2850 mhz phenomenom. What that means is no matter whether i use a winny venice clawhammer or sandiego i cant seem to go beyond 2850 mhz.....
go to Abit USA forum LVcoyote had a link there for bios 14 as well
2850 phenomenom hahahahaha i like it....
bellieve it or not, bios 14 actually help me clock higher than bios 13. 50mhz higher on my venice. speed is speed right? hopefully OFFICIAL bios 16 will help me out even more. I didnt try 15 cause of all the issues.
im on 15 now no real issues to report. Oc'ed a little no bsod however bios 15 seems to cause me to have a 2700 mhz phenomenon now...... anything over 2700 is unatainable and i got a weird code from my handy dandy port 80 diagnotic card not to be confused with abits post code reporter. the code is not listed in my post code definition book either. the code i received wasQuote:
Originally Posted by situman
( OP ) anyone care to guess what it stands for. my guess would be preety simple. O= Overclock P= Protection. Could this mean that abit is limiting the boards ability to OC? On another note with bios 13 my ram was (gskill) identified by spd as ddr 500 with looser timings. now its identified as ddr 400 with tighter timings. gonna play around a little with it. I might just have to do the 1mhz at a time trick as that has always seemed to get around ABITS noob protection as i like to call it etc noob shoots for 3 gig out of box board fails to post noob says ahhh shucks i got a crap chip and never tries again. :)
meh i need a link it seems that abit has made bios 14 dissapear i even was at taiwan site.........Quote:
why u no listen to me
ftp://ftp.abit.com.tw/pub/download/bios/an8/an814.exe
from abit forum
so you reckon venice goes higher on this one
hey guys my new venice seems to have a cold boot issues....WTF is that all about.....i have it at 2.8GHz 1.55V(i can go to 2.9GHz with this voltage so not the low voltage for sure)....restarting is fine...shutting down and booting up no go...need to do the cmos jumper
what happened to tictac...he probably got the boards and is going nuts OCing it :slapass:
could be utt issue like all the DFI boys. I shut my comp down for days sometimes and its boots right up with TCCD no problem. BTW thats a very nice chip you got there.
yah i found all the bioses still testing at the moment. So far i think bios 15 is best when using tccd for stabilty. still testing though.
I have a problem with my 3200+ venice with my TCCD rams on my AN8 SLi if i put too high a vdimm on my rams during booting into windows it will just power down or at high HTT and bios15 has read to write delay time stuck at 4 even i change it to whatever speed.
Originally Posted by Dark_templar
yep however bios 15 seems to be tccd friendly after conducting my tests.
bios 13 allows more headroom with tccd however prime fails after 4 hours for me
bios 14 allows higher cpu clocks lower tccd clocks and instant failure in prime when using tccd
bios 15 changes alot of the tccd timings however it seems to be coded for tccd as prime runs flawlessly.
were u able to get higher cpu overclocks with bios 15 and tccd?
its odd that really only a few people post about this board here. People need to realize how good this board really is.
I m having problems to get my rams higher then 280 mhz. Anyone can show me some of their sample timmings for tccd.
Nope no higher clocks but im beggining to think that my sandy is just a dog.
Meh I give up with these chips i have for now. Cmon chilly 1 I need - 25 temps :)
COUGH!!!! The Fatality AN8-SLI is completely PHUCKED in dual card sli configuration with bios 15.........NO 3D APP OR GAME WILL RUN, IT JUST BSOD's :fact:
What's the point in having a sli board that you want to use in dual card sli mode that DOESN'T EVEN PHUCKIN WORK WITH AN OFFICIAL BIOS (15). IN OTHER WORDS THE BOARD IS A TOTAL POS IF YOU WANT X2 SUPPORT AND WANT TO USE A DUAL CARD SETUP BECAUSE BIOS 15 WOULD BE THE ONE YOU WOULD HAVE TO USE AND IT BREAKS THE BOARD COMPLETELY :fact:
The whole senario with this board atm is pi$$ poor lame at best!!!. :slapass:
If i could get my hands on one i would post, not that i know much about overclocking :p:Quote:
its just a bios related issue. Once they get it fixed (whenever that would be) it should be fine.Quote:
Originally Posted by lowdog
I surely hope so.Quote:
The worring thing is that the beta bios 16_b00 Abit sent me had the same problem.
Surely Abit can't be that incompetent that they will release another official bios with the same problem.................but chances are they just might infact do just that. :nono:
Abit should really get those bios-teams to work because vurrent bios are really very bad... X2 problems (overclocking),Venice Problems (temperature and memory controller issues), SLI problems... way too much for me, going DFI real soon if the scenery doesn´t change...
Originally Posted by ukveld
I dont think DFI is much better, both have thier own unique set of problems. :rolleyes:
