thanks guys! ya also check out these, http://www.xtremesystems.org/forums/...&postcount=621
i finished a mod to cover up the side of the drive bays yesterday morning....took me forever but i think it was worth it
thanks again
thanks again
*whistle* sexxxxxyyyyyQuote:
Originally Posted by TheReds
How did you get the mesh to match up perfectly with the other bay covers?Quote:
Brendan
Maybe like this... [extract from http://www.xtremesystems.org/forums/...postcount=621]Quote:
that's aircooling: :d
http://img477.imageshack.us/img477/1616/img3638qm4.jpg
next time with thermalright hr-05 sli, i hope it would fit. :)
NVM, I thought he cut out the side panels to install the mesh on the 5.25 bays.Quote:
Originally Posted by GAM
http://img117.imageshack.us/img117/8739/img3598ja7.jpg
my 6800 ultra with stockcooler, but she is damaged (make pictureerrors :().
The Nvidea 6800 Ultra was a ground breaking great card
my new secondsystem:
http://img402.imageshack.us/img402/4272/img3732rc8.jpg
for the first time the boxedcooler is enough for my opteron 146, after that comes an other like infinity or some of this kind.
Nice clean layout AMD, well done.
good god how do you get your stacker so clean :(Quote:
Originally Posted by AMD_Deluxe
Cable Management is very easy on Stacker :)
Nice systems Guys , will post mine soon when ita finished. Keep em going
Here's a picture of the inside of my Stacker with a Zalman 9700.
http://i40.photobucket.com/albums/e2...7/DSC00190.jpg
sorry for the terrible pics no sata cables in the pic because I am getting new ones so didnt bother managing the oldies
http://weboperative.com/OCIDB/osamab...+/HPIM0033.JPG
This was the first boot of my RDX200, the cables are in a bit of a state but I was expecting to be pulling it all out, but so far its been running like a dream.
Just started overclocking yesterday with some new OCZ EL DDR PC-3200 Platinum's.
G'day all,
Some pics of my recent efforts on 'HTPC'
http://www.gam.net.au/pcmods/htpc/im...MG5483.25a.jpg http://www.gam.net.au/pcmods/htpc/im...MG5481.25a.jpg
http://www.gam.net.au/pcmods/htpc/im...MG5308.25a.jpg
Work log illustrating how I've modified my HTPC's generic case.
Some of the mods include:
- Front panel intake with MeshX grills and moulded fibreglass duct
- Top blow hole with anti-spill cover
- Noise dampening using adhesive foam
- Cable management mods to motherboard tray
- PSU cable alterations
- Interior paint
If you are interested, then please read on here...
Further mods to be performed include exterior paint job, maybe handles, side panel dampening and possibly small window (don't want to defeat the purpose of the noise dampening foam now, do I?), some subtle lighting 'bling' (at least behind the new front duct/grill) and any other good suggestions that people can come up with.
Cheers
GAM
that is realy clean, better then my pc.
i like clean PC ! Dont like those cases with mess inside !:cool:Quote:
Originally Posted by deepsilver
Hmz in those pic. missing my HDD and my Ati Radeon X850XT, but now those things are in place where they have to be ! :banana:
Sorry for my bad English :rolleyes:
Bad picture quality, but you should be able to tell what I have in there....
http://i2.photobucket.com/albums/y26...Inside4-Up.jpg
http://i2.photobucket.com/albums/y26...er/Inside2.jpg
I moved my room around and put my case on the floor next to my bipolar heater. It blows 90F air out the top and 45F air out the bottom. Well, I took advantage of the cold air and got some better clocks... 3.5GHz on my Connie for a bit on my SI-120. I had to reset my CMOS when I pushed for 3.6, too lazy to go above 3.2 now.
Cable management is quite a bit better than that since I got my 2 other hard drives for RAID... those pics were taken a few months ago.
Here is mine in my new gigabyte 3D aurora 570 case. Please excuse the fingerprints on the case :rolleyes:
http://i58.photobucket.com/albums/g2...O/IMG_9569.jpg
http://i58.photobucket.com/albums/g2...O/IMG_9572.jpg
http://i58.photobucket.com/albums/g2...O/IMG_9574.jpg
http://i58.photobucket.com/albums/g2...O/IMG_9578.jpg
http://i58.photobucket.com/albums/g2...O/IMG_9579.jpg
http://i58.photobucket.com/albums/g2...O/IMG_9591.jpg
@Sparky, it looks like a nice case. I like those ribbon style power cables, hmmmm...
Any mods planned?
Yes there are a few. I'm thinking of rotating the HD bay 90 degrees and making it removeable. Sidesaddle makes it easy to get drives in and out but it hurts airflow. Also this case will eventually house a watercooling setup, so the plan for that is to take out the topmost 120mm fan in the back, drop the PSU down to where it used to be, which then would give room up top for a triple rad.Quote:
This is all ideas though, not sure if I'll actually be able to do it. Especially the rear panel mod, that would take a lot of work to make it look clean and retain the overall case rigidity. If nothing else though, those stock fans have got to go - they look good but the airflow sucks. Maybe I'm just spoiled from my old aerocool turbine fans but at the same RPM those aerocools pushed a good amount more air.
