BIOS 1409 have 1.8MB then all other bios have 4.0MB. 1409 that is some patch?
Download from here please:
http://www.mediafire.com/file/3z99je...-ASUS-1409.rar
Thanks now 1409 work :up:
Edited
Malik has solved problem with SLI. Just flash all two gpu's from evga vendor vbios.
:rehab: :rehab: :rehab: :rehab: :rehab::rehab:
it's WORKING !!!
:rehab: :rehab: :rehab: :rehab: :rehab: :rehab:
http://www.abload.de/thumb/beztytuuh7x9.jpg
:bows: Thank You Guys :bows:
COOL !
it s possible to flash GTX580 TWINTECH bios to GTX580 EVGA bios ?
What settings do you guys use under the DIGI+ VRM settings.
Hi
i put this too be stable at 5Ghz
http://img29.imageshack.us/img29/4231/dsc05385ni.th.jpg
Uploaded with ImageShack.us
Can someone please advice me which PCI-E slot I should use for a 16x/16x SLI configuration?
8x/8x is better than 16x/16x? That's odd isn't it? Is there a way to do 16x/8x then?
Not without one card using the NF200.
I confirm the SLI problem (I have two 580 GTX)
It just don't wont to work with the latest 1409 bios . With 1485 is fine.
When using 1409 , with any driver up to 270.X it doesn't give you the option to select SLI in nvidia control panel . Only thing you can select is the physx processor .
If you try with the 275.X drivers and select SLI , the nvidia panel freezes and the 2nd VGA gives a yellow exclamation in device manager .
Hi,
Are you running stock GPU BIOSes? If you are:
Try uninstalling the second card via device manager, and then reinstall, wait for standard VGA drivers to install and then reboot and reinstall the nV drivers.
If that does not work then a reinstall may be needed.
-Raja
Nice application :up:
Boot:
http://img.photobucket.com/albums/v2...0M4E/stock.png
Subs with TweakIt:
http://img.photobucket.com/albums/v2...E/subs_1-1.png
Cannot change tWR, it goes back to value from bios after i hit apply.
Stupid question but should I use the red or black memory slots first for my dual channel memory?
Also my cpu core voltage is 1.04V, what should my I/O voltage be set to so that the spread is correct?
Thanks.
CPU is at 50x100 with mem 2133 :)
I'm more looking forward to the GPU based tweakit soft...
