Just like ADATA Hyper XPG+ kits were...
Loose binning, so your kit might need 1.5v to do rated specification while another might barely do it at 1.8.
Adata2000G v.2 @2133C7
Prime95 blend test (2Hr. 44min.)
http://www.picza.net/uppic/thumb/201...fd94fb6faa.png
Thanks: Ro ฝากรูป
http://valid.canardpc.com/cache/banner/1995894.png
sorry for my picture , it loading slowly
nice clocks, but wouldn't it have been cheaper to go straight for decent PSC kit ?
and LinX
http://www.picza.net/uppic/thumb/201...a5fecb3474.png
Thanks: Ro ฝากรูป
Patriot Viper II Sector 5 2250 9-9-9-27 (PVV34G2250LLK) Elpida MGH-E, 1.72v
Pre- test...
Attachment 120010
The one site I had read a few months ago, along with a spreadsheet with DDR3 overclocks showed SP1 as taking out a fair chunk of bandwidth. However, and I could be blind, but I don't see where it says he IS running SP1 :\ Unless you meant SPi, as in SuperPi...
I tried talking G.Skill into releasing a new kit for the AMD FX series... don't think they went for it lol
Attachment 120073
the new memories from GSKILL for AMD have F and X , but they aren't ripjaws :D :D
A bit of a rare set G. SKill Flare 4GB Kit DDR3 14400 CL7 8-7-24 1.65v, strips were taken 4х2GB, twin whales.
The first sets were released on ELPIDA MGH-E HYPER, then went to the PSC (Powerchip Semiconductor Corporation)
http://s09.radikal.ru/i182/1110/97/8ab830e66cbe.jpghttp://s54.radikal.ru/i143/1110/e1/95d96a32e7db.jpg
http://s19.radikal.ru/i192/1110/3e/1174fff73e52.jpghttp://s010.radikal.ru/i313/1110/67/f9e779f7ffa2.jpg
http://s61.radikal.ru/i174/1110/3a/5052e2343088.jpghttp://i038.radikal.ru/1110/8b/348c9f38308c.jpg
http://s09.radikal.ru/i182/1110/38/811201eef93c.jpg
For lack of a platform for AMD, has been tested on BIOSTAR TP67XE.
Profiles written into SPD.
http://s016.radikal.ru/i334/1110/fc/c4338e3a7a55.png
Starting at the same timings failed, had to raise trcd unit above is not clearly Elpida ...: scratch:
Omit samples and search for stable frequency / timings as that found for super pi 32m is 2133MHz CL6 9-7-24 1.68v.
http://s41.radikal.ru/i092/1110/0c/56adc06366ce.jpg
The highest incidence was unable to determine because of the weak bus in the processor. It is clear that AMD will reveal quite memory
And for a snack, something that inevitably would have to do :D
http://i046.radikal.ru/1110/67/3daca927bd67.jpg
These strips on Asus Crosshair IV running 6-6-6-21 bei 1800 MHz 1.65V
Let's wait for this set of tests Judge13
my Eco vdimm 1,65v
http://i798.photobucket.com/albums/y...a_eza/uhuy.jpg
more and max push at same vdimm
http://i798.photobucket.com/albums/y...za_eza/980.jpg
i bet can reach timing Flare @2000Mhz but i can't got stable :rolleyes:
please run 32m and see how far it can go regarding Eco.
I ordered 2133 cl9 Gskill 2x4 and will compare it with eco :p I Too bad 2133 cl7 is sold out for 4gb though it'd be funnier to test 16gb for OC in future
Deneb before week 15 2010 - up to 1.4v should be safe 24/7 after that follow thuban.
Thuban - keep it around 1.35v.
best ram for buldozer ? i cant get any to work over 1333 on my BD setup :(
What have you used till now?
Here is my FX-8150 with my Corsair Dominator GT-1600mhz 6-6-6-20 hypers from my X58 setup
http://i438.photobucket.com/albums/q...katoft/mem.jpg
any effect if for tRAS & tRC if both is below18?
tRC =11, easier on Thuban IMC = sometimes more ram clock to offset bandwidth losses. chew* described it as your heart skipping a beat, it won't kill you but its not optimal for efficiency. Keep it at tRCD+tRAS.
As far as tRAS goes, on Hypers above 1800 Mhz you MUST slacken to 17 in most cases, my ram definately didn't pull 15 much over 1600. I could run 17 until 1900 though. It will continue to need slackened as Mhz increases.
I would have to guess that Riska is up in 1.85v-1.9v land with his sticks. My STT 2000 C7 needed 1.91v to validate 2022 Mhz CL6-6-6 on Thuban. My kit is a little better than average Corsair 1600 C6 looking at other results.
