Here are some pics of mine. Specs are in sig.
http://img30.imageshack.us/img30/446/crw1072.jpg
http://img31.imageshack.us/img31/8518/crw1075.jpg
http://img132.imageshack.us/img132/1673/crw1052.jpg
http://img41.imageshack.us/img41/2716/crw1061.jpg
Good job Guitar, How is the rad working out for you top mounted like that?
guitar, love the rig bro. green looks great, I had green before, I miss it :(
(This was pre-T3)
I did some updates. Mostly sleeving and cable management.
I ran 2 separate runs in parallel to the GPU and CPU. It didn't effect temps at all. I just haven't changed it back seeing it hasn't effected temps ;)
http://i621.photobucket.com/albums/t...9/P1000258.jpg
Now updated with T3 (with faceplate:)) and HK 3.0.
http://i621.photobucket.com/albums/t...9/P1000275.jpg
http://i621.photobucket.com/albums/t...9/P1000278.jpg
@ rioja. Great stacker work:up:
Finally finished my i7 build. Overall, I'm loving the Xeon. 4GHz at 1.168V is lovely. :)
http://img40.imageshack.us/img40/7819/p1020171h.jpg
http://img44.imageshack.us/img44/6816/p1020172.jpg
http://img269.imageshack.us/img269/5035/p1020188w.jpg
http://img145.imageshack.us/img145/8677/p1020192.jpg
http://img41.imageshack.us/img41/4059/p1020187.th.jpg http://img188.imageshack.us/img188/6...020183o.th.jpg http://img199.imageshack.us/img199/2...020191t.th.jpg
classy use of LED's there, looks great :)
SimpleTECH
Very nice :up:
great pics SimpleTECH
simple tech, that is lovely dude :up:
Some pics of my just finished rig, some mistakes were made, some parts were damaged, next time I am aiming for perfection(no more letting the cat knock my case off a table!).
http://i20.photobucket.com/albums/b2...r/IMG_2985.jpg
http://i20.photobucket.com/albums/b2...r/IMG_2990.jpg
Gonna get some pics of it lit up when I get back from work, I ended up sanding my LEDs to give a more diffuse look to the light, very pleased with the way it turned out actually.
Very nice rig there NO1451 and I cannot wait to see it at a LAN party sometime. :up:
nice rig there No1451, shame about the cat knocking it off, just leave the side off and take of those fan grills and let it stand on a fan lol, sure it won't go near the case again.
I was also wondering what the water block was on you GFX, i don't think i have seen that before.
Cheers
Mongolian
Skilled thus far.
Nice build nemesis. I was contemplating getting that case and doing practically the same setup.
Heres my rig.
http://i213.photobucket.com/albums/c...g?t=1245476147
http://i213.photobucket.com/albums/c...g?t=1245476216
http://i213.photobucket.com/albums/c...g?t=1245476231
Pictures are kinda grainy/crappy. But you get the idea.
Nice Aviduser, I had my mcres mounted in the exact same place and it started to leak, only explanation is the heat of the graphics card not doing it any good. Luckily i had nothing sitting it the bottom of my case when it did go :D
Aviduser: Have any day time pictures of the front? I like the way it looks. :cool:
Where abouts did it crack? where u running distilled? Bah, these dam acrylic wc parts don't seem worth the hassle.
Just this older one (sorry about the quality)
http://i213.photobucket.com/albums/c...1/IMG_0057.jpg
Sentry Lx and a stealthed dvd drive.
Looks impressive and deadly, but I'm not gonna lie. It kinda freaks me out for some reason.
Nice work, though!! :D
All you guys are an inspiration. I can't wait to watercool my rig and add it to the great WC legacy here, but I'm waiting on that new Corsair Obsidian case to come out .... muahahhaa.
These rigs are all just awesome! :shocked:
Going to build my new system soon! (Can't Wait!!) :cool:
Having water cooling but do not know which one to get.... :shrug:
and yet again nice systems all! :D
Here's my new "toy", these shots are just "quick and dirty" made under the desk, but I will make some other soon...
http://www.abload.de/img/b_800x600_cimg6102xpx1.jpg
http://www.abload.de/img/b_800x600_cimg6112ntv5.jpg
http://www.abload.de/img/b_800x600_cimg6113hqob.jpg
http://www.abload.de/img/b_800x600_cimg6132jo3i.jpg
http://www.abload.de/img/b_800x600_cimg6124bobf.jpg
Nice rig Grossmeister, I've been looking at different MoRa 2 setups at HWluxx and im really diggin them.
Only thing holding me back is the flow restriction, only got a D5 to push liquid thru, second issue is making
the fan wiring clean on the MoRa....I hate cable salads, yours looks nice & clean tho.
I have an AquastreamXT, and flow's not an issue (OK, got that FuZion and the VGA-block in there only), but yeah, it's a little bit more restrictive than my triple + dual swiftech...but it still cools very well... :D
Getting the cable's clean ain't that big problem I think, I tied 3 rows of the fans together to the right (where the "cover" u-shaped aluminium is), and then soldered "+" and "-" together to one wire, which than goes into the old serial-port cable, which ends in the bracket, where 4 wires are for "+", and 5 for "-", it works perfectly, looks like, and with the Koolance shut-off valves, I can easily remove the radiator if needed :)
I built the aluminium-fan-holder on the MoRa myself, it wasn't that difficult, only the mounting of the feet was a bit difficult, but I built myself some rectangle-shaped nuts with an M4-coil inside, which is turned by the screw and then holds itself against the frame...
Beautiful build GrossmeisterB! You have some talent I see. Nice stand you built for the rad. Very clean!
