Originally Posted by
Manicdan
thanks for the tips, i messed up by not being able to really tighten down the barb first until after i had the compression fitting on, when i go to duel loop, when i care to get more tygon, ill do it your way.
also btw i need longer screws, i have acrylic holding these in, and the ones supplied are too short. is there anything similar to threading of your screws? i dont really have much to try it with since i have custom standoffs for my HDDs and i dont think its a standard cdrom screw.
