Still going.
http://img190.imageshack.us/img190/5573/stillgoing.png
Nice :up:
I wish my RAM wasn't holding me back :( Think I might stick some different sticks in there and see how high I can get the chip, then if its worthy...pick up some of the LV's and see if 8GB will run 550+ :D
Passed 6hrs+ Blend. Idle vcore between 1.392-1.408v because of no option for LLC, load 1.360v.
http://img188.imageshack.us/img188/1...hzblend65h.png
Very nice my friend as you told me yesterday i tried your settings in my Q9650 (512x8,5) with LLC enabled and same volts passed 7+ hours of blend at 1,36vcore
http://img16.imageshack.us/img16/1430/captura6h.png
Cheers :up:
Sergio
Very nice Sergio.
Trying 4400mhz blend on the DQ6 board.
http://img14.imageshack.us/img14/189...0mhzq95501.png
Still running 4400, will run this a while longer I hope.
http://img27.imageshack.us/img27/718...400mhz3hrs.png
Nice :D 1240+ RAM, what kind of Everest BW does it have at that speed? My UD3P needs PL9 at that speed but thats with 8GB of inferior RAM.
anyone tried this batch?
FPO/Batch #L848C311
6hrs and going strong.
http://img141.imageshack.us/img141/6...blendstabl.png
14 hours blend 4400mhz w7-64bit.
http://img10.imageshack.us/img10/148...ndq9550pas.png
how impressive !
Thank you.
Starting a new test, Prime blend 4450mhz.
http://img132.imageshack.us/img132/5...end1hr4450.png
WTB Everest results! :p:
Making me want to start using a pagefile again and go back to 4GB of some 9600's :lol:
Everest score,
http://img179.imageshack.us/img179/5350/cachemem2.png
Nice Work Guys :D Of Course OC Nub You Are Soo Activly :)
Some Worked In This Week:
Q9550 @ 4675 Mhz
Dram @ 1100 Mhz 5-5-5-15
ATI 4870X2 @ 750/900 Stock Clock
http://shahrsakhtafzar.com/img/out.php/t18832_83536.jpg
SuperPi1M @ 9.875 S
http://shahrsakhtafzar.com/img/out.php/t18831_9.875.jpg
And 1440Mhz Single Ram :)
Valid Link
Very nice work Vivid.
wow JUST WOW ViVid. Although too much V. for my poor x38ASUSMF AIR. FBS478 stable seems to be max. congrats
Alright I had to return the 070 chip I had because it was bad internally IHS wise. The damn thing was pushing 94c at 3.5GHz. I now have a 170 batch and it's VID is 1.2375 but, it is a hell of a lot cooler, it is running Prime95 at 4GHz 480 x 8.5 at a temperature of 65c on the hottest core and at a voltage right now of, 1.296. I will push it more later.
Q9550 batch L848C311 @ 475x8.5 1.23v
http://i26.tinypic.com/35bib20.jpg
