use what voltage you comfortable with
but i would not use over 2.3 for 24/7
why not 1225mhz you should be able to do it with 2.05v
@ 510 fsb you will go over 11k in everest
I quickly got my CellShock PC2-8500's @ 1066MHz 5-5-5-15 2.0v and 800MHz 4-4-4-12 1.9v. They were both stable enough 2 play games for ages.
I'm wondering if my Ballistix aren't GKX considering how much voltage they need to go over 600MHz...
also has alot to do with board/bios used as well and there's very very early D9GMH as well that didn't do as high as later revisions
Got some of the later stuff as well as old stuff..
later/newer 16FD5 and 16FD3 tracers
http://nx.i4memory.com/forsale/memor...500_002_tn.jpg
small segment of my D9GMH collection :D
Holy :banana::banana::banana::banana:
Sell this all and buy a car,dude :welcome:
That's just it, I have a kit of 16FD3 Tracers and 16FD5 regular Ballistix (both 8500), Cellshock 8000 C4 and C5, Team Xtreem 9600, Dominator 6400C3 (two kits) and 10000C5, XMS2 8500 (D9GMH), Reaper 8500 (old version with D9GMH), Geil 9280 C4 and some other stuff. Boards I'm using are Maximus Forumla with Rampage latest BIOS, Maximus II Formula, DFI LT P35, P5B Deluxe. You'd think SOME combination of the above could net me 650MHz+ stable :confused::shrug::mad:
how you define stable ? pi/3d benching is easy on different boards different levels of stability
http://fileshosts.com/intel/DFI/DFI_...4s672ms_sg.png
http://fileshosts.com/intel/Asus/Bli...cpuz_valid.png
http://fileshosts.com/intel/Asus/Bli...ms_everest.png
http://fileshosts.com/intel/DFI/DFI_...ms_everest.png
http://fileshosts.com/intel/DFI/DFI_...2m44s031ms.png
Outstanding results! Good job, Eva.
yeah i usually do at least 2 full passes and loop test #5 for around 10-20 passes before booting into windows
Shiranui, since DFI P35-T2R is board we have in common, back then I found clk fine delay crucial to breaking the barriers with Micron D9..
take a read of http://i4memory.com/f80/dfi-lp-ut-p3...ne-delay-4743/ and http://i4memory.com/f80/dfi-lanparty...eenshots-4487/ for DFI P35
For DFI X38 http://i4memory.com/f80/dfi-lanparty...friendly-5226/
with right combination of clocks and vdimm probably but i usually don't do that as the aim is for super pi 32m/dual 32m or 3dmark stable so unnecessary stress on system/ram would be wasted as i don't plan on running that 24/7 anyway.
or very very old/early D9GMH. I had one of the first released Team PC2-6400C3 no heatspreader D9GMH which was capable of high 4-4-4-5 up to around 610Mhz at very high vdimm 2.65+ but 5-5-5-15 didn't go any higher
Wow Eva, where did you get that warehouse full of memory ?, any of that up grabs ?
Don't stress about it, with the benches I have shown, I was nowhere near totally stable, just stable enough for whatever I was doing. None of the benches would have been SPI32M stable, I don't run memtest first I just guess volts/speed and boot and bench.
I am just now getting the time to run some SPI32M and the vdimm required for stability is much higher than required for everest/SPI1M.
Sure I can do 600 MHz at 1.98 - 2.02v with my GKX/GMH totally stable, but most GKX/GMH can. More than that and the required vdimm for stability increases rapidly.
Get in line (behind me) :p: I however doubt eva would sell any of his beloved ram, but if he does, he knows I'll take it :D
That makes be feel a bit better. I thought my memory sucked, or I just sucked at overclocking them. 600MHz is pretty easy to get stable with most of my kits, requiring 2.05~2.15V but some of the lower binned stuff needs more like 2.35~2.45V (my G.Skill HZ 6400 and Ballistix 5300/6400 come to mind). That being said, my CellShock kits are just weird. They don't seem to like too much voltage; if I go above a certain amount, like 2.25V with the 1000 C4 kit, memtest just locks up. :shrug:
ram addict that i am.. bought quite a few kits when they were available - i manually test each module properly match them in dual channel pairs - hence masking tape labels on heatspreader :)
plan to sell some locally in Australia but not sure what the going rate/price for these are outside of OZ ?? And well shipping would be expensive ...
1M vs 32M - 32m would need at least 0.1-0.15v more vdimm than 1M usually.
memtest lock ups on DFI boards can potentially be overcome via clk fine delay tweaking http://i4memory.com/f80/dfi-lp-ut-p3...ne-delay-4743/ . Example, I had D9GMH which had troubles stablizing at 600mhz 5-5-5-15 2.19v at first but clk fine delay tweaks allow same ram to shine at 640mhz 5-5-5-15 at 2.19v and 645mhz at 2.23v 32M stable http://i4memory.com/f80/dfi-lp-ut-p3...743/#post82457 ! ;)
http://fileshosts.com/intel/DFI/DFI_...3m48s578ms.png
Or if your ram is D9GKX, then it may not play as nice on DFI heh
Well shipping couldnt be that much to usa, they dont weight much :p: im interested in some, let me know.
you gotta try runnin some kits @ cas4 i have 2 sets of team that shine @ cas3 my ballistix love cas5
i had a kit doin 4-4-4-8 @1080 2.24v but they fell victim to my old gigabut board
its as good as doin 1200+ cas5
just run lowest volts to highest bandwidth to lowest latency for 24/7 benchin is another story anythin goes:eek:
I haven't got any lockups with my GKX kits, but I'm still experimenting with them to see what they can do. Do yours lock up just from voltage greater than 2.25v or also from going too far on a given voltage? I have run my GKX at 2.4v in memtest and they were fine. When I push them too hard, they just give errors in memtest or not exact in round in SPI32M, same as with my GMH.
Well I was trying to push them higher than 625MHz so I gave them more voltage, but it seemed to make things worse rather than better. My Dominator 10000C5 kit acts the same way, making me suspect there is GKX under the hood on those as well.
