Originally Posted by
DemonEyez
For people who are having trouble with modded bios and new drivers Cat 8.7 Cat 8.8. Here my story and possible fix:
My voltmodded (full load 1.35v) HD4850 runs with a modified bios which has 2D set to 160/300 @ 0.89v and has 3D set to 850/1150 @ 1.158v.
With Cat 8.6 i had no problems at all. These bios settings ran fine and were completely stable. Also I didnt have any blinking whatsoever.
Then Cat 8.7 came out. Right after installed those drivers (clean install) I started to have problems. I got blinking when the card was switching from 2d to 3d and got black screens and even lock ups when the card was under full 3d load during games. Reflashing my modified bios didn't work. I even changed it to higher clocks in 2d (500/500) and lower clocks in 3d (800/1100) But I didn't help.
So I reverted back to Cat 8.6 and all ran fine again.:confused:
Then Cat 8.8 beta came out. I hoped that my problem would be solved now, but alas, I experienced the same problems I had with Cat 8.7.
So back to Cat 8.6 it was.
I was beginning to suspect that there had to be something going on with my modified bios (based on the MSI bios) that wasn't working well with Cat 8.7 and 8.8 beta. perhaps it had something to do with PowerPlay in the new drivers
Then I did the following. I turned of my voltmod and I reflashed my card to my old original Asus bios and installed Cat 8.8 beta. All run fine now. Games ran fine and i had no problems, as is to be expected with a fully unmodded card
Then I turned on the voltmod, now the card only gets more juice. Still i had no problems, so I concluded that there was notihning wrong with Cat 8.8 beta and with my voltmod.
Then I redid the bios mod on a fresh copy of the MSI bios with RBE 1.13.
I modded it to the same values I had before (2d 160/300 and 3d 850/1150) flashed, and kept my fingers crossed.
And lo and behold: it runs fine now with Cat 8.8 beta. I get no blinking, black screens or lockups in games
So the trick for me was to install Cat 8.8 with a default unmodded bios in the card, and after the drivers installed then flash a new modded bios (which was modded with RBE 1.13) into the card
