http://www.forumdeluxx.de/gallery/da...anLiPC61-0.jpg
http://www.forumdeluxx.de/gallery/da...1wak_-sys2.jpg
http://www.forumdeluxx.de/gallery/da...1wak_-sys1.jpg
http://www.forumdeluxx.de/gallery/da...1wak_-sys3.jpg
Staucher
Is this Gpu Nexxos waterblock to heavy for the card? and does it it by somehow reduce the flow of the water. Its internal pipes is smaller that the most common watercooling fittings.
Hi
It is the NexXxos NVXP3 from Alphacool!
No is not Heavy on this Card.
the flow is good :)
x1900XTX stock-clock and Volts.. my Dual-Radiator with 2x120@7V
Mosfet ~68°C
GPU ~43°C
PCB ~44°C
good temps for noise-silent System :)
THx much for your answer. I have bought this too, but i am a little bit "coward" on installing it due to its weight and its smaller inner pipes. Anyway i ll give it a try...
update us on the temps.
some nice systems here. time to show off mine :D
here is my case. thermaltake armor with watercooling. specs in sig.
@ Staucher. Get rid of the 90' connectors.
@ haste. Very nice! :up:
90´Connectors?Quote:
Originally Posted by JoeBar
looks now
http://free.pages.at/speedy444/wak%FC-sys5.jpg
No with straight connections that cannot be done
the Temps and the flow are nevertheless very good
I like the front mayk freak grills =D Imo, a red lighting setup would look much better.
It looks very good to me.
Saw you´re using a nexxxos, is it good?
It is! :)
Staucher , did you do the carbon fiber work yourself? Either way looks good. Are you planning on doing anymore of the case in CF?
Yes :) Carbon foilQuote:
Originally Posted by lowfat
http://www.forumdeluxx.de/gallery/da...61-1-thumb.jpg
:nono: Crossfire is worthwhile itself not for me.
i have only 19 " TFT (1280x1024)
Originally Posted by Staucher
sorry i meant more of the case in carbon fiber, not crossfire lol. :p:
no is enoughQuote:
Before
http://www.forumdeluxx.de/gallery/da...PC61-0-med.jpg
http://www.forumdeluxx.de/gallery/da...PC61-1-med.jpg
Now
http://www.forumdeluxx.de/gallery/da...PC61-2-med.jpg
http://www.forumdeluxx.de/gallery/da...PC61-3-med.jpg
well i made some changes and this is wad my com looks like now!
http://i30.photobucket.com/albums/c3.../newcase3q.jpg
http://i30.photobucket.com/albums/c3...l/P1020201.jpg
Sladesurfer's Rig
what do you guys think? Nothing fancy:)
Asus P5WD2 Premium 955x
Intel Pentium D930
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400)
74 GB WD Raptor
XFX Geforce 6500 Pci-e Passive card
Ultra 500w PSU
Pioneer DVD-RW
Intel Stock Cooling
http://img333.imageshack.us/img333/6499/dscn13220el.jpg
http://img333.imageshack.us/img333/1374/dscn13199am.jpg
http://img243.imageshack.us/img243/8444/dscn13174sh.jpg
http://img282.imageshack.us/img282/7739/dscn13128aa.jpg
very clean inside
Very nice wire management. I like the neat and clean look myself.
Well done....sometimes less is more!
:toast:
