Here is sub 18 minutes for the green team:
http://img.photobucket.com/albums/v6...2Msub18min.jpg
Specs in sig.
Specs in sig.
12.xx
3259.9......kintaro..........12.59.422s......6x543 ...905.5mhz.....7-5-5-14....3/5..X48
11.xx
3900.1......CryptiK............11.58.140s.....7.5x 520....624Mhz.....5-5-5-15....5/6....P45
http://i266.photobucket.com/albums/i...z11m58140s.jpg
7.xx
4378.1......TinTin............7.59.922s.....21x208 .5....1042.4mhz.....7-7-6-19....2/10..X58
http://img357.imageshack.us/img357/9318/sub8min.jpg
8.xx
4405.0......mdobem............8.36.427s.....21x209 .8..........839.1mhz.....8-8-8-24....2/8..X58
http://img31.imageshack.us/img31/8137/superpi32m836.jpg
updated 7.xx, 8.xx, and 9.xx entries with 2k+ cas 6 on the R2E
i7 920 D0 + Corsair Dominator GTs on R2E
vanilla Windows XP SP3 with most services off
waza 1.9GB C: --> D:, D:--->C:, C:--> D:on .bat file run from desktop shortcut
7.xx
4359.8......alex_tpc............7.59.641....21x207 ....1038mhz.....6-7-6-18....2/10..X58
http://i404.photobucket.com/albums/p...1x207_6_sm.jpg
btw, got the evga classified 760 recently. can't run those mems with 2K+ even with cas 7 or 8 with the same proc on the classified even with high vtt. my proc's imc is probably not good enough for the classified or (and?) the classified really sucks with high uncore or(and?) i haven't played with it enough. edit: turns out to be due to a bad dimm slot on the classified :shakes:.
Really crazy CL6 over DDR3 2000:eek:, how much Vdimm you used? :clap:
8.xx
3864.9.......TinTin............8.59.422....19x203. 4 ....1017mhz.....7-7-6-19....2/10..X58
http://img190.imageshack.us/img190/6...0612011531.jpg
Can't wait to get in the race again, really. I am expecting good memories and a proper cooling and i'll post. Because at the moment it is ridiculous :p::p:
Good results over here :up:
alright guys, i think it is apparent i can't continue to update this thread. my year and a half is up doing so and it is time someone else took over. guys can't seem to follow the few simple things i ask for and i just don't have time to keep up with all of these entries. life is too busy for me right now and that isn't going to change any time soon.
so if you want to keep the the SPi Low-Clock Challenge alive, fire me a PM and i will give you a quick run-down on how to make it happen. only a couple simple steps really.
Hoping everthing is doing OK your side ! Even beter !!
Man, take care and please if you could, stay at the command :D
Alex_tpc > Amazing memory :up: What's this ? Sorted Hypers or...?
3oh6 > Sorry to hear you're leaving, i hope you'll find a good guy to replace you :p:
guilty as charged :sofa:. separating the posts to follow one score per post request from page 1.
8.xx
3842.6......alex_tpc............8.59.562....19x202 ....1011mhz.....6-7-6-18....2/10..X58
http://i404.photobucket.com/albums/p..._17x202_sm.jpg
[separating the posts to follow one score per post request from page 1]
9.xx
3427.1......alex_tpc............9.59.922....17x201 ....1008mhz.....6-7-6-18....2/10..X58
http://i404.photobucket.com/albums/p...7x201_6_sm.jpg
8.xx
3848.1......TinTin............8.59.797....19x202.5 ....1012.6mhz.....7-7-6-19....2/10..X58
http://img194.imageshack.us/img194/2...mhzsub8min.jpg
12.xx
3528.0......CryptiK............12.59.172.....7x504 ....604.8Mhz.....5-5-5-15....5/6....P45
http://i720.photobucket.com/albums/w...m593528MHz.jpg
i don't have money to buy good mems :(
this is the best i can do with the rated 1600mhz cas7 mems :D
7.xx
4419.8......DJSUB............7.58.703....21x210 ....1052mhz.....8-9-7-18....2/10..X58
http://img522.imageshack.us/img522/8...mhzspi32m7.jpg
Ok folks, I thought about it for a few days and had a nice alk with Jody and according to the fact that nobody else stepped up so far it`s my turn now. Fortunately I update many lists at other forums (partially for years), so I know how much work to expect. The reason I am into 32M and try to improve my efficiency also is helpful for sure.
I will try to do my job as good as Jody, because he really did a great job here. :clap: I am sure you all agree at this point.
But something has to change, so prepare for the following steps:
- To update the thread regularly and use the edit function I have to create a new thread. I will copy & paste the rules, the results and the thread title, so basically nothing will change.
- ...except for the AMD part. The results are not linked and there are also no informations about memory details or chipset available atm. I will cancel this old part and create a new one for AMD results. It is the better solution for future results.
- Of course the newer results we have seen here and were not added to the list already will be added to the new one.
Any ideas or wishes? Just leave a message here, drop me a PN or even look at the contact info at my profile. :yepp:
Regards,
Stephan
Stephan I know how hard Jody worked, I'm also involved with Greek SPi 32M LCC, basically the one who started it and keeps it clean :) (you already know it I know :D, I'm just saying ;)) I know how much work has to be done and in case you want some help, I'm prepared to help for sure. I'm a 100% in with what you mentioned about AMD list. If you want me to help you can discuss it with Jody and then find me on msn ;) :up:
12.xx
3254.9......kintaro..........12.59.375s......6x542 .5 ...904.2mhz.....7-5-5-14....3/5..X48
11.xx
3551.0......kintaro..........11.59.750s......6x591 .8 ...946.9mhz.....7-6-5-15....5/8..X48
Testing my new Corsair.
10.xx
3952.0......kintaro..........11.59.578s......8x494 .0 ...987.9mhz.....7-6-5-15....1/2..X48
09.xx
4424.3......kintaro..........11.59.969s......7.5x5 89.9 ...943.8mhz.....7-6-5-15....5/8....X48
very good job and very good cpu!!!
congratulations:):)
