Yeah.. check this out.. some further evidence
2x1GB Crucial Ballistix PC2-8500 Tracer @643Mhz 5-5-5-9 at 2.23v
Having too much fun with clock fine delay tweaking, really brings new life to my Crucial Ballistix PC2-8500 non-Tracer / Tracer memory modules!
Swapped in a 3rd kit, this time in dimm slot 2+4 with 2x1GB Cruciall Ballistix PC2-8500 Tracer modules. At first had troubles even with 600Mhz 5-5-5-9 PL6 at 2.19v with memtest86+ v1.70 test #5 having a few errors on 1st pass. Fine tune clock fine delay values and I'm memtesting without problems at 640Mhz 5-5-5-9 PL6 at same 2.19v vdimm ! 645Mhz 5-5-5-9 PL6 took only 2.23v bios set for single Super Pi 32M!!!! :D
This particular set of Ballistix Tracers took 2.4-2.45v to do 651mhz 5-5-5-15 on Asus P5K Deluxe!.
http://fileshosts.com/intel/DFI/DFI_...cpuz_valid.png
http://fileshosts.com/intel/DFI/DFI_...3m48s578ms.png
http://fileshosts.com/intel/DFI/DFI_..._bandwidth.png
DFI LP LT X38-T2R Bios Settings
PC Health Status
Adjust CPU Temp: +7C
CPU Feature
- Thermal Management Control: Disabled
- PPM(EIST) Mode: Disabled
- Limit CPUID MaxVal: Disabled
- CIE Function: Disabled
- Execute Disable Bit: Disabled
- Virtualization Technology: Disabled
- Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
Shutdown after AC Loss: Disabled
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock: Enabled
CPU Clock Ratio: 8x
- Target CPU Clock: 3433
CPU Clock: 429
Boot Up Clock: AUTO
DRAM Speed: 266/800
- Target DRAM Speed: 1290
PCIE Clock: 100mhz
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
Voltage Settings
CPU VID Control: 1.2875
CPU VID Special Add: AUTO
DRAM Voltage Control: 2.23
SB Core/CPU PLL Voltage: 1.51
NB Core Voltage: 1.591
CPU VTT Voltage: 1.382
Vcore Droop Control: Enabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Disable
x CPU GTL1/3 REF Volt: 110
x CPU GTL 0/2 REF Volt: 110
x North Bridge GTL REF Volt: 110
DRAM Timing
- Enhance Data transmitting: FAST
- Enhance Addressing: FAST
- T2 Dispatch: Enabled
Clock Setting Fine Delay
Ch1 Clock Crossing Setting: More Aggressive
- DIMM 1 Clock fine delay: 7 (raised from Current 2)
- DIMM 2 Clock fine delay: 7
- Ch 1 Command fine delay: 10
- Ch 1 Control fine delay: 7
Ch2 Clock Crossing Setting: More Aggressive
- DIMM 3 Clock fine delay: 7 (raised from Current 2)
- DIMM 4 Clock fine delay: 6
- Ch 2 Command fine delay: 10
- Ch 2 Control fine delay: 6
Ch1Ch2 CommonClock Setting: More Aggressive
Ch1 RDCAS GNT-Chip Delay: Auto
Ch1 WRCAS GNT-Chip Delay: Auto
Ch1 Command to CS Delay: Auto
Ch2 RDCAS GNT-Chip Delay: Auto
Ch2 WRCAS GNT-Chip Delay: Auto
Ch2 Command to CS Delay: Auto (where cpuz sees 1T or 2T SETTING)
CAS Latency Time (tCL): 5
RAS# to CAS# Delay (tRCD): 5
RAS# Precharge (tRP): 5
Precharge Delay (tRAS): 9
All Precharge to Act: 4
REF to ACT Delay (tRFC): 30
Performance LVL (Read Delay) (tRD): 6
Read delay phase adjust: Enter
Ch1 Read delay phase (4~0)
- Channel 1 Phase 0 Pull-In: Auto
- Channel 1 Phase 1 Pull-In: Auto
- Channel 1 Phase 2 Pull-In: Auto
- Channel 1 Phase 3 Pull-In: Auto
- Channel 1 Phase 4 Pull-In: Auto
Ch2 Read delay phase (4~0)
- Channel 2 Phase 0 Pull-In: Auto
- Channel 2 Phase 1 Pull-In: Auto
- Channel 2 Phase 2 Pull-In: Auto
- Channel 2 Phase 3 Pull-In: Auto
- Channel 2 Phase 4 Pull-In: Auto
MCH ODT Latency: AUTO
Write to PRE Delay (tWR): 14
Rank Write to Read (tWTR): 11
ACT to ACT Delay (tRRD): 3
Read to Write Delay (tRDWR): 8
Ranks Write to Write (tWRWR): 4
Ranks Read to Read (tRDRD): 5
Ranks Write to Read (tWRRD): 4
Read CAS# Precharge (tRTP): 3
ALL PRE to Refresh: 4
