:rofl: That reminds me of the glitch on Morrowind, where if you had 100+ acrobatics and you jumped you would fall through the canton and be stuck :rofl:
Heres mine @ Defaults:D
The problem is that there are points on each MAP where there was some type of Glitch. I got stuck between some lockers, I dropped a Laptop the wrong way and it killed me and etc....... I like the Game but I was surprised by how Buggy it is.
I kept my 3870 instead of taking it back. CoD4 and the other games I play look pretty good with it.
I can't wait, my 3870 should be here wednesday. What do you think i'll score in 3DMark06 with sig-rig? :D
Can't wait for the 45nm release, i plan on E8400 / X38 and might go crossfire :up:
Powercolor HD3850 256Mb Crossfire Default - Crysis GPU Benchmark
Q6600
Asus P5E
1680x1050
Windows XP
1680x1050 Medium Settings :
TimeDemo Run 1 Finished.
Play Time: 29.71s
Average FPS: 67.31
Min FPS: 46.50 at frame 155
Max FPS: 82.03 at frame 121
1680x1050 High Setings :
TimeDemo Run 2 Finished.
Play Time: 67.17s,
Average FPS: 29.78
Min FPS: 9.31 at frame 141,
Max FPS: 38.75 at frame 987
http://img153.imageshack.us/img153/5018/crysyscfde1.jpg
regards
There's definitely something wrong with that "crysis benchmarking"
AFAIK all latest runs perform same or bit better
I think that is absolutely not bad, for a HD3850 256Mb Crossfire Default .
I'm glad to see someone posting a real game benchmark again. (instead of the annoyingly useless 3DM06 scores), and showing how relatively strong this 'light' card actually can be in dual setup. Thanks Mascaras.
I think I am being bottle necked by my CPU.
See sig for full system speck.
One Card
http://service.futuremark.com/compare?3dm06=4026364
xFire
http://service.futuremark.com/compare?3dm06=4114217
Or do you think there is something wrong with my setup?
Of course you aren't "bottle necked by CPU", see the same CPU score in both benchmarks. EDIT: wait. I just saw you have merely a E2140. Yeah, could be the bottleneck...
Your CF isn't working correctly? Make sure you have default settings in CCC when you use CF.
Q6600 @3ghz => 17500 with gpu and ram @ stock ;)
The problem is not the software, it is the silly miss use of it that's kind crazy.
Most folks with Common sense know the software has a good use. It for checking like set-ups to make sure they're properly set up or tweaked. IMHO, it was never meant as software used for contests LOL! Geeks change this view and FM went along with them instead of re-stating what the h@ll it was meant for:) Too many it became 3D Bung-Holi-marks because of this *misuse.
Of course the software has no correlation to any Game;)
3870 CF is heavy CPU limited, even a 3,6Ghz quad is not enough.
Good work Mascaras!
I did Crysis x32/x64 tests @1680x1050 HIGH DX9 (under Win XP x64)
Phenom@2470MHz
Hd3870CF@800/1200
Crysis x32 - Average from 2,3,4 loop 38,9FPS
Crysis x64 - Average from 2,3,4 loop 42,01FPS
Bear in ming that I'm running only 2GB of RAM ATM. With 3GB+ Crysis x64 can load everything into memory, so higher averages and no shuttering during gameplay :) .
I don´t know man, but when I tried 3870 CF a few days ago there was a huge difference in scores (I mean, in SM2.0 and SM3.0) going from 3,3Ghz to 3,6Ghz. With more Mhz those things would fly!
My CPU seems a good clocker so I will aim for 3.6 now.
4GHz may be available lol (wish full thinking I know ;)) Bring on the water cooling.
not bad for a single 3870 and X2? all stock but cpu @ 3.33ghz
http://i151.photobucket.com/albums/s...m1/3d06800.jpg
what are your scores?
3DMark Score 10307 3DMarks
SM 2.0 Score 4411 Marks
SM 3.0 Score 5051 Marks
CPU Score 2385 Marks
http://service.futuremark.com/orb/re...0&UID=12663270
not bad, right?
Thanks alot.
you score is fine mate, here's mine for comparison.
One Card
3DMark Score 10703 3DMarks
SM 2.0 Score 4470 Marks
SM 3.0 Score 5032 Marks
CPU Score 2744 Marks
xFire
3DMark Score 13581 3DMarks
SM 2.0 Score 5753 Marks
SM 3.0 Score 7386 Marks
CPU Score 2742 Marks
With xFire my CPU is limiting it but I run 1680:1050 and crank up the eye candy to make up fir it :D.
Bring out the Yorkfields already!!!
oh yeah i hear ya, im running 1680x1050 too. Single card is almost exact same score!
I plan on picking up a x38 and a E8400 in late jan / early feb :up:
