6.13.3 beta:
Windows 32 bit
Windows 64 bit
6.13.3 beta:
Windows 32 bit
Windows 64 bit
6.13.3 is no longer available!
6.13.4 beta:
Windows 32 bit
Windows 64 bit
Edit:
OS X
OS X command line version
6.12.37 beta:
Windows 32 bit
Windows 64 bit
OS X
6.12.38 beta:
Windows 32 bit
Windows 64 bit
Edit:
OS X
6.13.6 beta:
Windows 32 bit
Windows 64 bit
Edit:
Linux 32 bit
Linux 64 bit
Edit2:
OS X
6.12.38 beta:
Linux 32 bit
Linux 64 bit
6.12.39 beta:
Windows 32 bit
Windows 64 bit
6.12.41 beta:
Windows 32 bit
Windows 64 bit
Edit:
OS X
Edit2:
6.12.38 beta:
Linux 32 bit
Linux 64 bit
6.13.8 beta:
Windows 32 bit
Windows 64 bit
Edit:
OS X
Edit2:
Linux 32 bit
Linux 64 bit
6.13.9 beta:
Windows 32 bit
Windows 64 bit
6.13.10 beta:
Windows 32 bit
Windows 64 bit
Edit:
Linux 32 bit
Linux 64 bit
OS X
6.12.43 beta:
Windows 32 bit
Windows 64 bit
Edit:
OS X
Edit2:
Linux 32 bit
Linux 64 bit
6.13.11 beta:
Windows 32 bit
Windows 64 bit
Edit:
OS X
6.13.12 beta:
Windows 32 bit
Windows 64 bit
OS X
Edit:
Linux 32 bit
Linux 64 bit
7.0.2 beta arrived:
Windows 32 bit
Windows 64 bit
Edit:
Linux 32 bit
Linux 64 bit
OS X
Disclaimer
On development versions of BOINC:
- Expect parts of it to be broken, or in the least to work in a different way than you are used to.
- Expect work failures, deadline misses and losing all your accumulated work in progress, or not getting credit for your work due to unknown and unforeseen circumstances.
- Only use it when you are willing to participate in the Alpha test program and do not mind sending (bug) reports in to the developers on the email list specially assigned for this purpose.
- Due to the OpenCL detection, your screen may flicker or turn off temporarily. This is normal.
7.0.3 beta:
Windows 32 bit
Windows 64 bit
OS X
7.0.5 beta:
Windows 32 bit
Windows 64 bit
7.0.6 beta:
Windows 32 bit
Windows 64 bit
Linux 32 bit
Linux 64 bit
7.0.7 beta:
Windows 32 bit
Windows 64 bit
Linux 32 bit
Linux 64 bit
Edit:
OS X
Has anyone on this board been testing these betas?
I've stayed away only because IIRC 7.X is a complete re-write and I'm not really an "alpha testing" type.
good morning Snow im running the 7.0.6 it has been stable but i have noticed they abort projects a lot before i can get to them,
i always like running beta :)
I typically do run the betas and I thank you for letting me know that 7.X is good enough to run :up:
Do you recall if there were any issues (cache and/ or project dumping) between 6.X and 7.X?
I just started crunching again i really got nothing to compare it with. but i got a new build coming in and i will give the 6x a try.,
7.0.8 beta:
Windows 32 bit
Windows 64 bit
Linux 32 bit
Linux 64 bit
Edit:
OS X
Edit: 7.0.9 beta seems to be canceled, not available anymore
7.0.10 beta:
OS X
