well, in general people are full of :banana::banana::banana::banana: anyway, so, why believe ANYTHING? :)
dave
here's another http://www.techwarelabs.com/reviews/...ors/barcelona/
Maybe you are right...
But you forgot one point: you are acusing, so it's up to you to prove the lie. :P
So the wait was over, buddy wants a new gaming machine and i think i will build it with Intel parts..
Last one was Opteron and really nice.
Yes after a LOT of ???? and again ???? for the 30k, others said it was with tri-fire, others at lower resolution than default, others that it was the 2k5 and not the 2k6, others that it was the 2k5 with lower resolution and others that it really was 2k6 with CrossFire.....What is true and what not, perhaps we will NEVER know it.....
No. Read it again:
http://www.theinquirer.net/default.aspx?article=41970
He gave a lot of detail and info. He said 2 cards, what speeds they were clocked at ect. It's just that the results he reported given the setup he reported were and are impossible. All of the speculation was on what way he might have gotten it wrong.
Ok, so here is an interesting question. For AMD processors, what sort of changes or differences occur-if any-between the opteron and desktop series? I realize that there is different binning, etc, and memory controller differences, but anything else specifically?
I'd say mostly BS at this point. Anyone able to read a little could make up the details he gave. But, as you said we'll have to wait a see.
Talking about the 30K 3do6
Looks like the previously leaked benchmarks were real.
Well, I can't say I'm surprised, but damn, the K10 can't even match the C2D clock for clock, and it has a much lower clockspeed. It really looks like AMD just slapped an shared L3 cache on the K8 and called it a day. But if they did that, it should've came out a lot earlier. Well, hopefully it'll hit 3ghz by the time the desktop Phenom launches, otherwise AMD is :banana::banana::banana::banana:ed. This is even worse situation than the R600, at least the HD2900XT was competitive.
a.) coherent dual HT links for inter-processor communication (which has not realistically benchmarked)
b.) n-way scaling (8xxx series)
c.) RAS features including more pertinent/efficient binning processes
i probably could keep talking about it, but why bother?
dave
really? hmmm...i don't see that at all.
*yawn*
you DO realize that phenom will use DDR2-800, will launch at higher clock speeds, and will have better mainboard support at launch?
comparing C2D to a server processor is like comparing a Humvee against a X5. On pavement, the X5 will "win." off road, the Humvee. Two different focuses with two different applications.
calm down.
dave
Because they received guidance from you know who ...
There is one where disabling the HwP helps : SpecJBB.Other than that it is a major player in Core's performance.
I'll give you something more to think about , the anbormally poor showing of Xeon in SpecJBB :
http://www.realworldtech.com/forums/...82680&roomid=2Quote:
Two flaws IMHO
1) They used an old version of the Sun JVM, from before Sun adopted Intel HW. That old version contains optimizations for AMD but not for Intel. A more recent Sun JVM (1.6.0_02) or a recent version of JRockit would have resulted in much better Xeon scores. While they had a valid reason for going with 1.5.0_08 (be able to compare with old results) they should have mentioned this fact in the article.
2) They worked around the main AMD weakness (poor performance if accessing non-local memory) by running with several JVM instances, each affinitized to a NUMA node. Xeon does benefit from multiple instances too, but not nearly as much as AMD does. For completeness, they should have run in a single-JVM config too, or without using numactl.
Henrik Ståhl works as a product manager in the JRockit team, and has been with BEA since 2004.This guys definetly knows his stuff.
What it means is that the mobo only "officially" supports 667 DDR2. It doesn't mean that you can't run faster memory. I believe the "Phenom" test was done on a Supermicro board which are some of the most solid server boards on the market, but lack almost any overclocking features whatsoever.....;)
