Thanks man, will check that out when I get home!
I got this board a E6600 (L629F) a Ultra-120 Extreme , DRR2 1066 RAM from Crucial
I've never overclocked before where should I start?
Dr.D. start by bookmarking and re-reading this entire thread from start to end ;) If you want a more tidy version with uninterrupted posts.. check out the original at http://i4memory.com/showthread.php?t=4027
okay Ace-a-Rue, slaughtered, cooked and served for your digestion :D
http://fileshosts.com/intel/Asus/P5K...3m05s562ms.png
George for president, Ace-a-rue don't mess with this guy , he will make you cry. He's mister memory !!!
LOL :)
2x1GB Twin2X2048-10000C5DF Dominator
Asus P5K Deluxe 0311 bios
I decided to revisit my 2x1GB Twin2X2048-10000C5D Dominator memory rated at DDR-1250Mhz 5-5-5-18 at 2.4v (kindly supplied by Corsair :) ).
http://i4memory.com/reviewimages/mem...000C5D_006.jpg http://i4memory.com/reviewimages/mem...000C5D_011.jpg http://i4memory.com/reviewimages/mem...000C5D_012.jpg Originally, even with 0311 official bios the 10000C5D Dominators were a bit more than flaky on P5K Deluxe - understandably so as 10000C5D Dominators are validated only on eVGA 680i motherboards. But it seems now that I am retesting them in black dimm slots instead of yellow dimm slots, they're alot more stable particularly at 4-4-4-x timings needing less vdimm and clocking a bit tighter on memory timings in black dimm slots than in yellow dimm slots!
http://i4memory.com/reviewimages/mem...000C5D_013.jpg http://i4memory.com/reviewimages/mem...000C5D_019.jpg http://i4memory.com/reviewimages/mem...000C5D_022.jpg
Note, prior to these tests all my 2x1GB memory testing to date on P5K Deluxe has been in the yellow dimm slots.
System
- Q6600 QUPT B3 ES
- Corsair Nautilus 500 3/8" ID
- Asus P5K Deluxe 0311 official bios
- 128MB Gainward FX5200 PCI
- 2x1GB Corsair Twin2X2048-10000C5D in black dimm slots
- 74GB WD Raptor 8MB on SATA 2 port
- Pioneer DVR-08 Burner
- Sony FDD
- 1KW PCP&C SLI psu
- WinXP Pro SP2
I managed to pull off some quick tests for low clock Super Pi Challenge @3600Mhz and managed my fastest Super Pi 1M and 32M times to date for a quad core Kentsfield Q6600 cpu :woot:
CPUZ Validation
http://fileshosts.com/intel/Asus/P5K..._validated.png
Super Pi 1M
http://fileshosts.com/intel/Asus/P5K...m_13s906ms.png
Super Pi 32M
http://fileshosts.com/intel/Asus/P5K...3m10s829ms.png
From my experience on Asus P5B Deluxe, quad core kentsfield B3 stepping is around 10-20 seconds slower clock for clock than core 2 duo B2 dual core cpus. And even my personal best E6700 B2 dual core time on P5B Deluxe @3600Mhz is only 13min 08ish.
Will have to do some more tests with black dimm slots it seems :D
Edit: okay confirmation from bingo13/Gary from Anandtech here, black dimm slots are designed to do this according to Asus!
Edit 2: Yup can confirm now black dimm slots rule for 10000C5D Dominators on P5K Deluxe
Black dimm slot = 625mhz 5-5-5-15 3-30-3-3-8 at 2.4v memtest able
Yellow dimm slot = 590mhz 5-5-5-18 10-42-10-10-11 at 2.45v semi stable in memtest
Huge difference!
YOU are a good sport:D ...i will concede that the P5K is slightly faster in at least the SuperPI category; BUT, not by much..hehehehe:p:Quote:
Originally Posted by eva2000
Geat find Eva... nice to have the confirmation as well (albeit after the find lol)
I wonder if the same holds true for any of the P5B range? Might have opened up another whole playing field? Can't help wonder and hope someone way above me has a crack at testing it out.
I wonder what would happen if you guys disabled cores? For Conroes IMHO most 965 and P35 perform nearly identically at the same speeds. It seems like the P5K just has an upper hand with quad cores...
on my P5B Deluxe both dimm slots were about the same no one pair of slots was a clear winner like on P5K Deluxe.
Yup also can re-confirm now black dimm slots rule for 10000C5D Dominators on P5K Deluxe
Huge difference!
This does not bode well for anyone trying the C2D's in all 4 slots :(
not really just means a bit more tweaking
Quick run with 2x 1GB Team 6400C3 D9GMH + 2x 1GB G.Skill 6400PHU2 HZ D9GMH on Asus P5K Deluxe @490mhz 4-4-4-9 2-25-2-2-4 (tightest subtimings possible with bit more vdimm)
http://fileshosts.com/intel/Asus/P5K...width_cpuz.png
http://fileshosts.com/intel/Asus/P5K...3m52s578ms.png
http://fileshosts.com/intel/Asus/P5K..._32m_1024m.png
Buffered
http://fileshosts.com/intel/Asus/P5K...i/mem_buff.png
Unbuffered
http://fileshosts.com/intel/Asus/P5K...mem_unbuff.png
More tests to confirm that indeed black dimm slots on Asus P5K Deluxe seem to clock these 10000C5D Dominators alot higher with tighter timings and lower vdimm than yellow dimm slots.
System
- Q6600 QUPT B3 ES
- Sony FDD
- 1KW PCP&C SLI psu
- WinXP Pro SP2
Corsair 10000C5D Dominators:
Using memtest86+ v1.70:
Yellow slots = 590mhz 5-5-5-18 10-42-10-10-11 at 2.45v memtest semi stable
Black slots = 625mhz 5-5-5-15 3-30-3-3-8 at 2.4v memtest able
In windows had to loosen the subtimings up and drop the clocks a bit for 2.4v vdimm but still @620Mhz 5-5-5-15 8-30-8-8-8 at 2.4v is much better than Yellow slots @590mhz 5-5-5-18 10-42-10-10-11 at 2.45v which was only semi stable in memtest.
JumperFree Configuration Settings
AI Overclocking: Manual
CPU Ratio Control: Manual
- Ratio CMOS Setting: 9
FSB Frequency: 388
PCI-E Frequency: 100
DRAM Frequency: DDR2-1242
DRAM Command Rate: 2T
DRAM Timing Control: Manual
CAS# Latency: 5
RAS# to CAS# Delay: 5
RAS# Precharge: 5
RAS# Activate to Precharge: 15
TWR: 8
TRFC: 30
TWTR: 8
TRRD: 8
TRTP: 8
DRAM Static Read Control: AUTO
Transaction Booster: AUTO
Boost Level: N/A
Clock Over-Charging Mode: AUTO
CPU Spread Spectrum: Disabled
CPU Voltage: 1.475v
CPU Voltage Reference: AUTO
CPU Voltage Damper: Enabled
CPU PLL Voltage: 1.50
DRAM Voltage: 2.4
FSB Termination Voltage: 1.40
North Bridge Voltage: 1.55
North Bridge Voltage Reference: AUTO
South Bridge Voltage: 1.20
Advance CPU Settings
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
PECI: Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support: Disabled (need to enable it to detect USB flash drives)
CPUZ Validation
Everest Ultimate
http://fileshosts.com/intel/Asus/P5K..._bandwidth.png
Short Prime95 v25.2 blend test
http://fileshosts.com/intel/Asus/P5K...blend_load.png
Super Pi 32M Single & Dual
Single 32M
http://fileshosts.com/intel/Asus/P5K...3m48s891ms.png
Dual 32M
half way mark
http://fileshosts.com/intel/Asus/P5K...2m_halfway.png
Complete
http://fileshosts.com/intel/Asus/P5K...i-32m_dual.png
Sandra XI SP2
Buffered
http://fileshosts.com/intel/Asus/P5K...em_buff_tn.png
Unbuffered
http://fileshosts.com/intel/Asus/P5K..._unbuff_tn.png
Hey EVA, forget benching, your should start up a screenie composite posting championship. Man you got it down to a science. I'm way too lazy. ;)
"Hey EVA, forget benching, your should start up a screenie composite posting championship. Man you got it down to a science."
He does. Eva, are you on vacation or something. All that takes much time. It is very helpful though and nice find on the dimm slots. Reminds me of the orange and yellow ones from awhile back.
nah not on vacation but read my forum member title
<=== :D
great results eva2000.
gives me hope that i can get more out of my OCZ Platinum chips which have turned out to be pretty disappointing. cant run DDR2-1000 4-4-4-15 with 2.35v or 5-5-5-15 at 1200mHz at same vDIMM. think its safe to run 2.4v w/o active cooling on the chips?
time to try the yellow slots :D
Been playing with my P5K Deluxe + E6400 for a bit now. Currently has 0311 bios. For some reason, my system sorta hangs for no reason at random intervals. It's not a stability issue, it's something else, like the BIOS is just stopping for no reason or something. I'll be running Orthos for awhile, and the OS just sorta stops responding. Orthos continues to still run, passing tests, but AI Suite/Core temp just stops updating, Orthos timer stops, the "GO" flashing stops, Tests continue to pass, can't even push the Start menu, Mouse still moves, but everything sorta just hangs there. I can't even turn the system off using the power switch, I have to turn it off using the switch on the PSU. After letting it cool off a bit, I go back into the BIOS, and the clock is behind, as it seems the time stopped after the "hang" occurs.
Anyone experience anything similar? Really need to figure out what's causing this. This is happening on stock settings even, it's really strange. Got a 40gb IDE hooked up, a sata optical drive on the black slot, both controllers running IDE mode. PSU is Corsair HX520.
