Vista Home Premium x64, 'World Community Grid BOINC Client 5.10.45' (:shrug:).
Yeah, 920. I hate the i7 name. It reminds me of S Club 7. I'd rather just use the code name. :p:
Same machine, 3.6GHz.Quote:
01.01.2009 20:13:31||Running CPU benchmarks
01.01.2009 20:13:32||Suspending computation - running CPU benchmarks
01.01.2009 20:14:03||Benchmark results:
01.01.2009 20:14:03|| Number of CPUs: 8
01.01.2009 20:14:03|| 3486 floating point MIPS (Whetstone) per CPU
01.01.2009 20:14:03|| 8829 integer MIPS (Dhrystone) per CPU
01.01.2009 20:14:04||Resuming computation
920 at 3780 (180x21), uncore at 180x16, 6 GB of RAM, Vista x64, BOINC 6.2.18
With all kind of things running in the background, but I don't think that matters much.Code:2009-01-02 00:50:28|| Number of CPUs: 8
2009-01-02 00:50:28|| 3439 floating point MIPS (Whetstone) per CPU
2009-01-02 00:50:28|| 11445 integer MIPS (Dhrystone) per CPU
Actually, yeah it does make a difference. Shutting down unused background processes raised the bench on this Opty 185 by 50 points, and it didn't start with that many daemons running.
Thanks for the benches. :up:
edit: Oh and errrm ... which Vista x64?
Like that made any difference D_A ;)
Same rig, same settings, Vista Business x64, switched BOINC version to 6.4.5, an behold, 60 points less int and 1000 points less float :shocked:
Gotta strip my Windows to the bare minimum and check if this result is consistently repeatable.Code:2009-01-06 01:12:08|| 3382 floating point MIPS (Whetstone) per CPU
2009-01-06 01:12:08|| 10551 integer MIPS (Dhrystone) per CPU
I tried it the other day on my X2 with a 8600GTS and it only does the CPU benchmark (6.2.19) but I can try tonight with 6.4.5 if you want?
If you don't mind. I'm just curious if it does a GPU benchmark as well.
Vista Ultimate x64
Boinc 6.4.5
A few things in the background, Coretemp, RealTemp, Pidgin, Daemon Tools, foobar2000, and Opera. The other 24/7 stuff.
i7 920 at 3.8 Ghz w/Turbomode (QPI=190)
3x2GB DDR3 1520
3788 Whetstone
9474 Dhrystone
My Tpower I45
XP64
BOINC 6.4.5
3263Whetstone
10061 Dhrystone
3074 / 6560
Specs in sig.
E6420, Windows XP Home SP3 32-bit, BOINC 6.4.5
Thank you. :up:
Same system and clocks, boinc 6.5 x64. OS XP 64 2003
1/7/2009 4:09:22 PM||Benchmark results:
1/7/2009 4:09:22 PM|| Number of CPUs: 8
1/7/2009 4:09:22 PM|| 3469 floating point MIPS (Whetstone) per CPU
1/7/2009 4:09:22 PM|| 12085 integer MIPS (Dhrystone) per CPU
I'll keep an eye on my stats for this rig at my grid page to see actual production differences.
funny how x64 affects one bench more than the other..
