I hope that my DS3 on monday arrive, then I will test my E6400 Step 5 :)
3.3 GHz w/1.4v?
ok then...i can do 3.1 GHz w/1.31v :)
I guess i was a bit too optimistic ;)
What cooling are you on mr roadster?
66*C is a bit hot no?
Easy tune doesnt work on my rig, so i have no idea what my temps are :p:
K.I.T.T. Have you tried flashing back to the original BIOS, then install EASY TUNE, then flashing back to your current BIOS, F3 I assume?Quote:
Originally Posted by K.I.T.T.
Kitt : Cmos and reinstall Easy tune at stock freq.
Easy tune Center is not Easy tune, be carefull ;)
Originally Posted by theteamaqua
thx for the tips. too bad my memories are weak. i had one value 2gb corsair ddr667 with micron chipset that can do over 800 but the other one with unknown chipset max around 700 only. So sad coz at first i got a pair of ram with micron chipset which can do 800 @ stock vdimm but suddenly one of the ram died. Send for replacement and get the normal chipset :(
now i'm running my e6300 @ 2.45ghz, 350x7 ram @ 700 5-5-5-10 :P and everything at stock voltage. while this speed is better than my opty 170 @ 2.8ghz (my daily use speed) but it just a waste seing 3ghz chip running at less than 2.5ghz :nono:
in the driver CD, it only has "Easy tune Centre" option :confused:Quote:
Originally Posted by misteroadster
no, easy tune only, not center :D
eh, issit all intel mobos dont have ram divider option to allow we running ram at lower frequency than the processor? like in AMD64? or it's just this gigabyte board?
All of them i think. Even on my P5W DH, the lowest it DDR2 533.
i use Gigabyte Rocket cooler 2 :rolleyes:Quote:
66° is not so hot, if it's stable, it's ok :)
is the cooler really hot ? It's probably not accruate
Yes cooler is hot, even at stock voltages :)
Ambiant air too , about 35°
toujours la canicule a Paris ?Quote:
with normal temp (20-25) it could possibly do over 3.4ghz :)
Oui on crève !!
Surely, i will probably test some cold on it soon...
Now all I need is a Conroe (and some better cable management probably haha). :party:
http://www.damontech.net/system.jpg
aldamon wtf is that big black thing in the bottom of your case over the pci slots ?
hey KITT you can do 3.3 on air with defualt vcore. so dont worry about it. 3.3 isnt an issue for vcore.
i can do 3.6 w/ 1.28 or slightly less.
vdroop on these boards is very small also which is nice.
It's a Sytrin KuFormula VF1 Plus:Quote:
Originally Posted by Lestat
http://www.newegg.com/Product/Produc...82E16835150072
It's not blocking any of my PCI slots on this mobo, only PCI-E 1X slots. The angle of the photo is bad.
http://www.damontech.net/vf1pci.jpg
Originally Posted by aldamon
That Cooler is hugeee!:toast:
http://images10.newegg.com/NeweggIma...150-072-04.jpg
holy crap wtf is that thing!!
can you compare it to like the NVSilencer ? or is it better ?
Turbine fans typically are very loud.
I believe that is called a squirrel cage fan, such as used in a furncace.
squirrel cage turbine tomatOes tomAtoes
What type of fan (make/model) could I mount on the northbridge heatsink on this gigabyte board?
461 fsb so far for meQuote:
not sure how how 5400UL will scale at 4-4-4-12 so I stopped at 461fsb primed overnight
still on stock volts
Have you guys had any issues with Northbridge temperatures? I am worried about this issue if I buy this mobo.
