http://112233445566.free.fr/PM780/3809%20PM780.jpg
skirms_fr
Congratulation!
It is stable?
skirms_fr very nice chip :toast:
here is my 730 under cascade
http://slike.slo-tech.com/17634.jpg
http://slike.slo-tech.com/17635.jpg
thx :)Quote:
Originally Posted by angru
not stable , its a max screen :)
@sharp , its a very good chip you got there , my last 740 under cascade was maxscreen @ 3588 and max spi 3469 :)
your cascade is R1150 ?
mine is with R290/R170
R1150 is too expensive in france :mad: :slapass:
thx,you got very good numbers with ethane cascade ;)
yes my is r1150 cascade,but i have some problems with contact,even with heatspreader on :shrug: i need to fix the problem
http://112233445566.free.fr/PM780/ihs%20pm780.jpg
ihs on the 780 :p
i have polished the twice face of the ihs with P2000 :D and the evaporator too
ATM i need as ceramic and r1150 :)
and my gto² that is RIPP :o
what do you guys think, i have it at 30% overclock now, i am sure it can go up to 3.0ghz what do you think?
http://img.photobucket.com/albums/v71/elyrly/b.jpg
http://img.photobucket.com/albums/v71/elyrly/a.jpg
easy elyrly, go up untill you find its limit. temps look good, so go for it.
It depends alot on how much you can push the FSB. You can check this by lowering the multiplier if you dont want to give it too much voltage. Anyway, my wild guess is 2.8-2.9GHz at best.
Asus p4c800 gold full moded Vcore, Vdimm, Vdrop
Asus ct-479 full moded Hipro5 mod vcca 2.3v
OCZ DDR Booster moded 3.5v
Pentium M 730 1600@2906 vcore 1.6v
Kingston HyperX BH-5 242Мгц
Vapochill XE
Windows 2003 server
SuperPI 1.4 1M = 24.672
http://img389.imageshack.us/img389/1487/246720oi.th.jpg
I have a question for all 865/875 + Dothan (or P4 2,4 NW) users:
Is there anyone who uses the 5:4 divider with a FSB of 300 ? That would give a memory speed of 240 Mhz.
I want to reach this speed but I don't know what modules to use... Currently I am running with 2 x 512MB BH-5 but my modules will not go over 270 FSB (mem @ 216) with any timings. They run at FSB 301 3:2 or 240 1:1 with 2-2-2-5 PAT perfectly.
BH-5 is the best for the 875P chipset to achieve low timings, but I think maybe newer DDR500 modules could do 300:240 with loose timings.
I have already tested with 2 x 512MB Mushkin XP4000 Redline but this memory craps completely on 875P.
Maybe Samsung modules do better, or Crucial Ballistix ? Hope you guys have some thoughts about this (old problem :rolleyes: )...
It is hard to run 300fsb+ on P4C800 :confused:Quote:
Originally Posted by FreeRider
I manage 297MHz fsb stable, and 305 for 1M Pi
http://img106.imageshack.us/img106/6...97pi16m6ol.jpg
http://img48.imageshack.us/img48/5176/fsb305pi1m5ob.jpg
old scool BH5 (Ididn't try tis with 2x512 :rolleyes: )
My 2x512 Bh5 can 245Mhz max in 16M, and 257MHz in 1M super PI (on A64 thay do 267 16M)
What is the best bios for the P4P800E-Deluxe? Should I use the P4P800SE bios?
if you want to be able to change multi in bios, the p4p800se bios is the way to go, otherwise, i think the normal P4P800-e bioses are the way to go.
Other then changing multi nothing changes?Quote:
Originally Posted by skane
not that i noticed, voltage regulation, fsb change, all stays the same afaik.
Do you have a link for the bios 1009.003 for the P4P800SE bios? Al links I find are death..
does any one have the file for AIbooster the asus website doesn't have it anymore.
ANYONE?
Pentium M 780ES C0 @ 3307MHz 1.6v 236*14
Vapochill XE
Kingston HyperX BH-5 @ 236Мгц 2-2-2-5 OCZ DDR Booster moded 3.5v
Asus ct-479 full moded Hipro5 mod vcca 2.0v
Win 2000
SuperPi-mod1.5XS 1M = 22.641
http://img391.imageshack.us/img391/7500/226418ag.th.jpg
Originally Posted by Razor_Sniper
take it from here Klick ;)
Pentium M 780ES C0 @ 3399MHz 1.8v 242*14
Vapochill XE
Kingston HyperX BH-5 @ 242Мгц 2-2-2-5 OCZ DDR Booster moded 3.5v
Win 2000
SuperPi-mod1.5XS 1M = 21.984
http://img139.imageshack.us/img139/8325/219842cw.th.jpg
page not found :/Quote:
Originally Posted by C_B
I still have it if you wan't it.Quote:
Originally Posted by skirms_fr
i d like :)
I can have a Pentium M 740 1.73 for 40$. It's this cpu; www
When I look a the number of pins I can see it's a 478pins. Would it work without any adaptor like CT-479 on the asus board or do I have to buy that adaptor?
Thanks :toast:
For the PM740 Dothan, you'll definitely need that adapter and the right Asus board/BIOS too.
