Wow! This case with goodphotos looks even better. Those Gelid Wings UV Blue match very well with yout Sleeving, nice choice.
I'm very exctied about what are you going to do with that case on your worklog. ¿Where did the 840 go?
I sell it. New user will make LC in this 840.
Wow. :shocked:
Awesome Fractal.
Is that an Alpenföhn Matterhorn on your CPU ?
Nordwand Rev.B ;)
Ah ok :D
Good performances ?
What's new:
Case: Fractal Design R2 Black Pearl
CPU: SilentiumPC Fortis HE1225
Other: Enermax UCMA12 Magma 120mm, Noise Blocker BlackSilent Pro PK2 140mm
Here some new photos:
http://www.abload.de/img/3w74y.jpg
http://www.abload.de/img/47mb5.jpg
http://www.abload.de/img/10l74o.jpg
Ah Malik, your PC builds are beautiful both air and water cooled! Truly an inspiration for quality and beauty.
Here's my box. It's not anything special. Just a few fans and such.
Some update... new fans on noctua etc.
http://lh5.ggpht.com/_ewMJ_gKYs2k/TC...4/DSC_3469.JPG
http://lh3.ggpht.com/_ewMJ_gKYs2k/TC...4/DSC_3478.JPG
testing in progress...
Haha you changed the fans! You cheater... you can't have Noctua performance AND good color scheme!
When will someone here test the new Zalman CNPS9900 MAX?
http://www.techpowerup.com/img/10-06-04/16a.jpg
modded 7950x2
all go no show
i just bent an as1 to fit on the inside core
http://img692.imageshack.us/img692/5820/p6182693.jpg
http://img189.imageshack.us/img189/6910/p6182692.jpg
http://img718.imageshack.us/img718/826/p6182691.jpg
as for effectiveness..... it might be overkill putting fans on it ;)
i dont think theres a case that can contain it thuo.:D
Well i call it air cooled......
http://i186.photobucket.com/albums/x...624_072640.jpg
Hybrid!! ;)
Definately air cooled, seeming as it's on par with most air coolers
