Originally Posted by
Amurtigress
Hello,
I hate to admit it, I just can't get my Q9300 stable,
despite my over a decade lasting experiences in overclocking.
Here is my current situation: Most system crashes/freezes are
accompanied by several WMIxWDM errors, Event type 122. Bus Interconnect
error. They occur a few times in a row before the system hangs up.
See bottom of this post for error details
To me this feels like an error on the FSB...it annoys me terribly
that I've got no clue what else could cause this besides the FSB GTL
reference, the FSB termination voltage and the CPU VCore.
My current board is a standard Maximus Formula V1.03 with Rampage BIOS 0308,
running a Q9300 at 3.26 GHz. 4x1 GB Corsair XMS2 DDR2-800 RAM
Another question: 1.40V FSB term. volt. are usually being considered the limit
for 45 nm CPUs. Does this refer to the ASUS' BIOS setting, or to the ACTUAL
sensor readings which are usually 0.08V below the bios setting?
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
Ratio CMOS Setting : 7.5
FSB Frequency : 436
FSB Strap to North Bridge : 400
PCI-E Frequency: 100
DRAM Frequency: DDR2-874
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 12
RAS# to RAS# Delay : 4
Row Refresh Cycle Time : 60
Write Recovery Time : 6
Read to Precharge Time : 4
Read to Write Delay (S/D) : AUTO
Write to Write Delay (D) : Auto
DRAM Static Read Control: Enabled
Ai Clock Twister : Light
Transaction Booster : Manual
Common Performance Level [8]
CPU Voltage : 1.25
CPU PLL Voltage : 1.50
North Bridge Voltage : 1.61
DRAM Voltage : 2.00
FSB Termination Voltage : 1.34-1.38
South Bridge Voltage : 1.050
CPU GTL Reference : 0.67X
North Bridge GTL Reference : 0.67X
DDR2 Channel A REF Voltage : DDR2-REFF
DDR2 Channel B REF Voltage : DDR2-REFF
DDR2 Controller REF Voltage : DDR2-REFF
SB 1.5V Voltage : 1.5
