bummer, ive had worse motherboards survive better lol.
how is Abits RMA service? Is it worth it to do the advance motherboard shipping?
i am going to give 17.b02 beta a try to see if that has corrected the problem.
EDIT:...looked at that link and i think Deanzo was using 16.b04 (crappy with Vista64) which was the only bios, that i was aware of, that unlocked the 9650 above its default multi of 9X...well...off to see if 17.b02 works its magic with my 9650.
DOUBLE EDIT:...NOPE!...same old thing with my 9650 and 17.B02 beta bios...multi is locked out above 9X
If you're refering to my processor sitting at 75, its because the bios i am using reports high temps. Its about 25 degrees over what it should be. Also, those temps are just after the wprime run finished, so i still have a good 10 degrees or so to play with (I go by temps on the cores as opposed to the processor temp which is lower than the core temps with 16.03 bios)
that is what i remember reading...they are slow....i think like 3 weeks turn-around time.
I do advanced-exchange almost everytime I have a component go bad; it's never worth waiting upwards of 3 weeks to get your board back if that's your main PC. :(
No doubt. but before I send it out, This is a video. Dead, yes? Even with nothing attached, it still just does code 8.2
VIDEO
These 4 driver sets are all newer versions than what Nelly has posted on page 1 of this thread:
REALTEK High Definition Audio - Version 1.93
http://www.station-drivers.com/page/realtek.htm
Intel Chipset Device Software - Version 9.0.0.1008
http://www.station-drivers.com/page/intel%20chipset.htm
Intel Matrix Storage Manager - Version 8.0.0.1039
http://www.station-drivers.com/page/intel%20raid.htm
JMB36X RAID Controller - Version 1.17.37 WHQL
http://www.station-drivers.com/page/jmicron.htm
Nelly
what's the word on the IP45 Pro or X48 release time?..june or later?
Nelly probably knows better than I, but a couple people (not necessarily with inside knowledge) guess June. The IP45 Pro is being displayed at Computex 2008, so that's encouraging. Of course, it was displayed at CeBit too and still remains unreleased. You are definitely not the only one waiting for them. :)
Have a problem and I wanted to pick your brains a bit.
My entire system shuts off (even the cute blue LEDs in my Antec case) and then comes right back without reboot to the same web page or program that was up????
I seems to happen primarily to my wife logged on in her settings of Windows (XP 32).
RAM, PSU, or does she just have bad computer Karma?
?!? Let me make sure I'm reading this right...it actually loses power for long enough that the LEDs go dark and then turns back on, right where it was in Windows?
I've had power flicker VERY momentarily and this happen, but it wasn't even long enough for the fans to lose momentum and was caused by storms / surges. Is she doing anything that can be repeated to reproduce the error consistently? Has it ever happened with you at the helm? And now, some random guessing:
- My first thought would be the PSU of course.
- Try moving the power cable around and see if that reproduces the outage...could be a bum wire.
- Remove all but one stick of RAM for a while, see if it happens again. If so, try the other one. Then try a different DIMM and so on and so forth.
- Remove any overclock you may have.
Extremely curious. :shrug:
Hi Guys haven't lurked here in a while! Been too busy to mess around with my IP35-Pro.
I was wondering does anyone know of anyone who has watercooled the whole thing? i.e. mosfets and NB & SB? I was thinking of putting mosfet coolers from Enzo on the mosfets and MCW30s on the NB & SB but havent seen it done yet.
Cheers,
emu
Hi, I know just as much as you i.e. I dont know. :eek: :D
Mentioned in another thread, by the time the Abit X48-Max is released the only people who will probally want them is people with review boards :shrug: Abit have left it far to late to make it worthwhile purchasing because everyone has bought X48 boards from either Asus, DFI, MSI, Gigabyte etc, it's usually DFI who are slow as hell at releasing motherboards yet they managed to release the X48 boards as quick as Asus usually do.
The Abit P45 chipset boards should be in June, I really want the Abit IP45 GT3 if it's not in stock by July 1st, I will buy an alternative P45 motherboard from another manufacturer - end of story.
I can't stand Asus due to pathetic RMA service, but I might risk it & go for the Asus P5Q3 Deluxe.
