^ Nice TRUE Copper!
^ Nice TRUE Copper!
When I had the Kandalf case I dremelled two holes in the motherboard tray which worked a treat. Only problem with it was that I bought the black one which weighed a tonne wheras yours is mainly aluminium
I'm sorry to say that, but you should change your opinion about this case because it is easily moddable. No pun intended, bro.
Here is my Kandalf with my previous 4890 cards (Those two pci-e power cables are visible because i was too lazy to hide them when i took the photo)
I will take pics of the current setup later when i finish work:
http://www.shrani.si/f/y/Ld/3thTmVLT/dsc02372.jpg
Not to forget, that there are a lot of people out there haven't any experience with modding a tower, or in the worst case they will not even have any tools to do that.
To be honest, i do not really like the Kandalf. But sure you are right with the fact, taht modding will get it a lot better for cable managment. Did that to all my cases in the past! :)
On-Topic:
http://www.gravedigga.de/gravedigga/PC3/4.jpg
http://www.gravedigga.de/gravedigga/PC3/5.jpg
http://www.gravedigga.de/gravedigga/PC3/6.jpg
My third pc a long time ago.
Thanks for all your answers. I think I will make two holes in the Kandalf to hide the cables. Thank you for your advices !!!:yepp:
Or in the other case they haven't enough time to mod a tower.Quote:
My current workstation...But I don't like this Case. It is to small :(
Maybe I will buy a Silverstone TJ09...
http://www.abload.de/thumb/cimg0027qvvm.jpg
http://www.abload.de/thumb/cimg0013gmfj.jpg
@funkflix Loving that oldschoolness :]
I've modded my kandalf yesterday. I've never modded a case before...
It doesn't look perfect but I think it looks a bit better than before. ;)
It looks a LOT better! :up:
#6336
karbonkid
karbonkid's Avatar
__________________
My new build (WIP) - http://www.xtremesystems.org/forums/...d.php?t=232626
MSI K9ND Speedster-WA6
2x Opteron 8220
2x 2x2GB PC53000 ECC Reg DDR2 @ DDR702
GeForce 8500GT
LSI SCSI320-2e PCI-e SCSI controller -
Cheetah 15k.5 73.4GB @ / (xfs)
2x Cheetah 10k.7 73.4GB RAID 0 @ /home (ext4)
Etasis ET750 PSU
2x MCW60 --> Apogee 1U CPU blocks
EK NB/SB 6 chipset block
XSPC RS320
Primchill T3 running rad in parallel
SWEET:clap: I like I so LIKE
I went ahead and took the pic out THOMO sorry about that.
@Thermaltake Fan
Much better looking now. Bet your well chuffed with the results. Looks a million times better now.
So with all the update,s heres a recent pic...
Basically got the frame powder coated along with the rear side panel...didnt come out too well, but it will do for now. It has a few blemishes here and there, but mainly on the rear side panel. some updated hardware as well and my new rams and PSU.
http://img130.imageshack.us/img130/7391/img1615ko.jpg
You just cannot imagine how easy it is to work with flat ribbon cables compared to the fat ones. This PSU is just awesome, quiet and takes a good amount of load.
@ gatecrasherlok
To make a hole in the motherboard tray was a good advice. Thanks.
Flat ribbon cables?
^ from the psu I think he means.
So, the PSU comes with flat ribbon cables. Very cool. Maybe my next PSU.
hello, there do you think of my box after having painted.
has no stickers xD
before
http://img62.imageshack.us/img62/3655/09052010432.jpg
after
http://img139.imageshack.us/img139/2331/17052010470.jpg
thanks to all :D
@>D4L70N<
Looks much better than before ! :)
thanks!
I have seen the change of your thermaltake, is much better :D.
>D4L70N< & Thermaltake_Fan Both of you have done a real nice job on clean up!! :up:
