1/2'' looks like primochill tubins they ara just too fat :)
here take a look on the left is primochill on the rihgt is on normal ordinary tube
http://img266.imageshack.us/img266/9...1854lg1.th.jpg
yes it is primochill, theres nothing wrong with it being thick, seeing as its the best tubing to work with. :cool:
I nearly finished my system, maybe I gonna change the color of the mb loop to a deep red and clean it a bit.
Well it does not look that perfect like other ones but I'm fine with the temps :)
just testing a q66 for a friend of mine.
http://www.gwebspace.de/sargatanas/P...2.07-innen.jpg
http://www.gwebspace.de/sargatanas/P....07-grakas.jpg
Sargatanas,
How do you connect your two stacked cases ? I'm highly interested in that arrangement. Do you drill through the floor of the top case and through the ceiling of the bottom case?
Many thanks / Danke
DarthBeavis,
It looks like the much ballyhooed quad SLI is on its way, but only in the form of a 9800GX2 style card (remember the 7950GX2?). This time, quad SLI is going to work properly and work well. I got burnt the last time.
Pure speculation but there are lots of circulating rumors that Six-Way SLI will be coming as well, eventually. You obviously know that, because most the rumors are on NV's forums, no doubt hyped by the company itself.
The Skull Trail mobo's fourth PCI-E slot would not be useful because of the dual slot nature of the GX2 card.
The Chinese talk about a February 19th date. Warning that this is speculation (with all due respect to the Mainland Chinese) and that the release date may distinctly be an Asian release date, and as usual, the rest of the world sucks wind for one month before getting access to the toys.
http://en.expreview.com/?p=133
What am I? A fool? You probably have the cards at home already, beta testing them rofl :)
well the bottom case has a huge hole without the plate which is normally mounted.
http://www.pc-cooling.de/images/prod...84300-6_gr.jpg
I changed the plate from the upper tower aswell so I was able to use a dual radiator at the top.
http://www.pc-cooling.de/images/prod...0100109_gr.jpg
then I drilled a huge hole at the right part in the floor of the upper case where the psu takes place. the hole is big enough for all the hdd cables, tube etc.
wasnt that difficult...looks a bit messy atm but I think I should make some pictures of the right parts of each tower.
makes it easier to understand the mounting since my engl. is quite poor atm ^^
the loops run through both towers, since the bottom chamber is only for testing atm
Thank you very much.
Do you use nuts and bolts to fasten the two cases, use velcro, or use nothing because the cases are so heavy ?
well 3x 8mm bolts on the left and 3 on the right side. is quite enough since the towers weight too much to carry it, think 'bout 50kg.
Thank you very much!
http://forums.erodov.com/imagehostin...2ac3c0b7ee.jpg
Just installed and leak testing ^^
http://forums.erodov.com/imagehostin...2ac3c94380.jpghttp://forums.erodov.com/imagehostin...2ac3d3c55e.jpg
http://forums.erodov.com/imagehostin...2ac3de4cc9.jpghttp://forums.erodov.com/imagehostin...2ac3e4d6fe.jpg
http://forums.erodov.com/imagehostin...2ac3f0914f.jpghttp://forums.erodov.com/imagehostin...2ac40b11ca.jpg
Yes, those are Martin's T's and Elbow!
Took these pics over 2 weeks back.
Worklog and More pics
THIS is not my build...just thought I should show off the sweet tri sli power...
3D mark 06 score: 21,844
Tri SLI 8800 GTX
http://img46.imageshack.us/img46/832...4101sn3.th.jpg
After much time and hard work, my first water-cooling build is complete, for now. If anyone would like, I'll make a thread with more pictures. I wish they were of better quality, but its the best camera I have at the moment. Feel free to ask any questions.
Computer specs:
Asus Blitz Formula
EVGA 8800 Ultra
E6700
2x1GB Crucial Ballistix PC8500
150GB Raptor
Corsair HX620
Lian Li PC-A70B
Cooling:
Thermochill PA120.3
D-Tek FuZion
Swiftech MCW60
DDC 3.2 w/ Petra's top
All fans are low speed Yate Loons at 7v
http://i38.photobucket.com/albums/e1...a/9aa03979.png
http://i38.photobucket.com/albums/e1...a/0b3a861e.png
http://i38.photobucket.com/albums/e1...a/172f5d26.png
http://i38.photobucket.com/albums/e1...a/da0ebc52.png
That`s very nice build, that is what good wire managment should look like. :)
Yeah, I would like to see moar pics. :up:
Nice build gs274...Heppy New Year for all ;)
New WC Setup
Added a MCRES & an MCR120 to the front... and the DFI and a Q6600 :p:
http://i120.photobucket.com/albums/o...p/IMG_0073.jpg
Lights out.
http://i120.photobucket.com/albums/o...p/IMG_0070.jpg
Crowded tubing
http://i120.photobucket.com/albums/o...p/IMG_0075.jpg
Mounted the rad with the two U shaped MCRES brackets.
http://i120.photobucket.com/albums/o...p/IMG_0078.jpg
:cool:
nice and clean msarp
HAPPY NEW YEAR!
http://i152.photobucket.com/albums/s...s/HPIM1428.jpg
http://i152.photobucket.com/albums/s...s/HPIM1427.jpg
http://i152.photobucket.com/albums/s...s/HPIM1425.jpg
http://i152.photobucket.com/albums/s...s/HPIM1420.jpg
And my old P4 machine, ahhh...presyyyyyy.
http://i152.photobucket.com/albums/s...s/HPIM1454.jpg
http://i152.photobucket.com/albums/s...s/HPIM1453.jpg
http://i152.photobucket.com/albums/s...s/HPIM1452.jpg
http://i152.photobucket.com/albums/s...s/HPIM1451.jpg
http://i152.photobucket.com/albums/s...s/HPIM1449.jpg
http://i152.photobucket.com/albums/s...s/HPIM1448.jpg
http://i152.photobucket.com/albums/s...s/HPIM1445.jpg
http://i152.photobucket.com/albums/s...s/HPIM1437.jpg
http://i152.photobucket.com/albums/s...s/HPIM1433.jpg
@CyberDruid: man, you make water-cooling look sooooo easy! drool :up:
@ [XC] Kayin . . .Cooling quad with Two Thermochills in the loop, 10 SilenX in push/pull;)
@ Bla$nA . . .Don't worry, I will have new cards eventually . . .sponsors FTW ;)
@ Zgradis . . .Quad SLI = Intel SkullTrail . . .Tri SLI = Nvidia 780i . . .I do both
@ IanY. . .Single slot bro. Slots inbetween are usuable if the card is not tall. These blocks perform and I have numbers to prove it. My understanding is no connector needed for quad.
@ lennox . . .yes, that is an issue
I am waiting for a pump to arrive so I can change my setup to waterchill using the phase change unit. I was unable to get a good seating on the CPU on this board so my temps sucked.
I am working on getting procs for the SkullTrail and need get blocks made for the SkullTrail yet including a GPU solution.
DarthDeavis TEN silenx fans.... oh lord :(
