Ah, paparamiro, you take such sweet shots.
Here's mine.
FYI I have...
CPU: i7 @ 4.5Ghz
GPU: Dual 295's (Currently will be receiving 3 EVGA GTX 480 Superclockers in 2 days)
Harddrives: Dual X25-E EXtreme 64GB Solid Slate Drives in RAID0 and 2TB Seagate storage.
Memory: 2203Mhz 8GB 7-8-7-20 Corsair Dominator GT
MOBO: EVGA Classified 762 4-way SLI full 7 16x express speed lanes.
Case: A full sized closet! ROFL. lol the 4-way sli mobo requires more slots so I need to find a case.
Cooling: Air! yah extreme air! using a modified and hacked V8 cooler. see pic
On to the news. I have an open-air rig and use a giant utlra high velocity fan and an air conditioner lol. It's not all connected because I'm rewiring everything and waiting for my Tri 480SC's from newegg. I do plan on going with 4 if they serve me right.
http://img710.imageshack.us/img710/8515/dsc04451x.jpg
Well okay... why do you have the motherboard sitting in midair and not resting on a flat surface, picture needs resizing.
Sorry for the picture size. This is not how the board will be finally layed out. It will be stable and it's in mid air so it can be cooled underneith the hottest part of the mobo. The temps change dramatically when cooled under. If it was flat then the temps climb even higher. I wish I would of done this a long time ago so thanks to it being in mid air cooled from both sides I can get much better clocks.
Wow poparamiro that is one of the best mirror finishes I have seen :up::clap:
Thank you, some of shots are ok but far from a lot other shots of my very talented colleagues from here.
@ V0id
Yeap, Balder's base is very nice (is a stock base)
http://forum.lab501.ro/attachment.ph...1&d=1271332028
first build in 12 years, still tweaking but well on the way:
http://farm3.static.flickr.com/2740/...0e420f12_b.jpg
What are you cooling with the zalman fan?
Probably just moving air over the back of the gpu?
I would point it towards the back of the case though.
there's a mobo chipset heatsink, you can just barely the edge of it there.
nope.. zalman is creating flow over silent pipe cooler on the UD7 :D
its been a while.
http://i5.photobucket.com/albums/y18...x/IMGP9549.jpg
Don't know if this qualifies, but this mATX build has 2 x 80mm, 1 x 60mm, 3 x 40mm (5.25 bay), 1 x 80mm GPU, and lastly 2 x 40mm HDD cooler. :D
http://i34.photobucket.com/albums/d1...v4Left3-41.jpg http://i34.photobucket.com/albums/d1...rkLeftSide.jpg
And yes TSXmike all blue! :rofl:
nice builds! ive always wanted to build a mATX setup.
btw... i did find some 120s in red... so a color change might be in my future... just need to figure out how to change the LEDs in my sunbeam rheobus.
