3.107 Uguru version should be the only version to use...it is the latest version that works in Vista 64...but...to close it, you have to use the task manager (under 'Applications' tab) in vista 64...32 bit OS, it will close out normally.
Uguru is an excellent hardware tool...you are self-defeating yourself with this board by ignoring it or not having it active...of course, the latest version is the only one to install...doubt that Abit's disc has the latest version on it...you need to download version 3.107
i recommend two fans...only need to be 40mm's with some decent CFM...NOW...if you never get it up there with all four cores, you might be able to get away without them...BUT...any time you do Prime 95, you better have fans blowing on the NB and PWM heatsinks.
I'll have to give it a try...
I ironed out my oc 6 months ago and have been folding non stop since, so I rarely play with it anymore. it's just a workhorse now... plus I'm not a gamer, so the majority of my pc time is media center, ati 650 tv card, internet, email, office, cd/dvd burning, an basic non extreme type things. only reason I need the quad and oc is for folding...
it's a great dependable board... It runs non stop 100% folding on 2 smp clients for about 4000ppd, and records about 30hrs of tv a week on a media center schedule. no intervention from me except to do what I want as a user everyday. the only time I really reboot anymore is for updates or power failures..
but maybe I'll check out the new uguru for grins..
Oh, OK!...that makes more sense...now that you explained it, i see why you are not toying with Uguru...Uguru is a good one to tweak that final voltage to make it stable...sounds like you already have a VERY stable system!
Is anyone else running a Q9450 in one of these?
What's the lowest you can set your vcore to? I've only tried the 17 beta with this chip but can't set it any lower than 1.2375v. The VID's 1.1250v according to Core Temp.
uninstall Uguru even deleting the folder...shut the computer down and now clear the CMOS with battery out for about 5 minutes...after doing that, re-enter the bios and load "optimized default" settings; save!..go back into the bios and now set it up the way you want it.
go into windows and now re-install Uguru version 3.107...lets hope this gets you back on track.
Any feedback on what the best BIOS is to use?
Using 17b2 currently, but everyone keeps talking about 16b10...
Just curious if I should roll back to that beta or not?
I've got a X3350, i think the chip has more than my current 3.6 but anything past 450fsb starts getting really unstable. :( I need to play with it more next week.
Also, with the official 16 bios i was able to run it at its default vid, I think mine was the same as yours.
Damn good thread. Ive read through a lot of it, but I may of missed some posts. What are most people pulling on a Q6700 on water? Im just waiting on my new ram.
Not sure an average Q6700 speed. However, if you're interested, there is a whole other thread by this same name at the abit forums (and it's 133 pages long). There is a lot to read, just like this one...but if you want to and if it helps, great!
They need lots of VTT and MCH voltage to get over 450mhz. I can get 475mhz OCCT stable with VTT at 1.32v and MCH at 1.52v. You'll probably have to mes with your GTL's as well.
I passed 8 hours of Prime95 small FFT's last night at 475x8, but she froze as I was setting up the screenshot :shakes:
Gonna try again today.
Upped the vcore by 0.01v this morning and ran it in Vista this time. Failed after 5 hours.
Trying again with another 0.01v. If that falls over then I'll play with the NB voltage again. I've already had to up the NB to 1.52v for 3.8ghz.
I'm dreading to think what NB voltage I'll end up at when I'm trying it with 8gb installed.
Gezz 2 weeks of reading!!! :shocked: keep up the good work ! :clap:
Now I can post my noob questions :P
Here's what I have done so far.
First step: can my cpu and my board can handle 500 fsb x 6 .... a simple increase to increase mch@1.37 done it.
Rock solid !!!10 hours sp2004 x 2 with large ffs. followed by a 10 hours mem test.
Second Step: I assumed that the only thing I had to do was to increase vcore and fsb at x9 multiplicator.
so far I can play and do my stuff at 446x9 =4014mghz vcore@1.4750 in bios 1.43 to 1.41 in cpuz under load. I fix my mem@1.20 to be around 1066 @ 2.2250v to 2.2 under load.
**edit**cpuvtt@1.20 since I read it can help in Oc but in my case no real impact****
but now I cant get the same stability in one of the sp2004... after < 2 hours one of the sp2004 (oftenly the cpu0) stop working.
Do you know what should I increase to get a little bit more stability on sp2004? maybe more vcore...
yeah yeah I KNOW sp2004 means nothing but to me it does.:yepp:
btw I know my english is not perfect. :(
fast answer! I'll try this very soon I'll keep you inform.
