Try again with 2810MHz 1.36Vcore and CPU-Z on screenshotQuote:
Originally Posted by babyelf
Thank you
Thank you
here
babyelf you have same stepping as me
:D tedy
how is urs doing?
it's really bad :(
needs 1.485v (1.425v cpu-z) for 311*9
altho mine cooling sux but on the other hand temperature are way below 50°c so i got no clue what's wrong
bios?Quote:
Originally Posted by TEDY
5/10-3 let me write everything in sig.
hmm same.. 510-3 as well.. orange slots for my bh-5
3ghz WOOT
0517 GPPW
Stock air:
240*10 with stock voltage prime95 stable
270*10 @ 1,72V 32M stable
babyelf: what cooling do you have ?
using my corsair cool now :)
snapped it up for a bargain tooQuote:
edit: lol in 3 months you've posted 50 posts more than I have done in almost 3 years
arf i hit 3ghz but then my system crashed :p
In a month if i got some more time then i am going to tweak my venice a bit.
Must have 2.9ghz stable at 1.55-1.6V :D
3ghz? :)
yeah nice but your stepping is better then mine :)
ok. but which code ? which is the important code or week ? I think "paw" is good code :confused:Quote:
Originally Posted by TheMeatFrog
week is more important. Week 17 and some week 16's are good. *PAW and *PMW are both very good.
AIRCOOL : XP90C with 90@5V
IHS REMOVED idle 23°C 21°Room (mobo on a table)
http://www.yamafoto.com/users/vroom/...n9cyc9xxkh.gif
I'm beginning to think it is my board which is holding me back. My 0446 winchester and both 0517 and 0518 Venice chips perform the same
~2400mhz on stock voltage
I have been plagued...
Just got a week 19 3200+in from monarch and it sucks ass. Will only do 2.4 no matter what voltage I put through it. If I clock it any higher, it just crashes when I try to bench it with superpi or prime.
Guess my 2.6 week 16 wasn't so bad after all.
Don't feel that bad.Quote:
Originally Posted by fullup3
I went through a 0517 and 0518 which clock exactly the same, 2700mhz with 1,7Vcore
I believe its my board though, as 3 of my cpus have clocked almost the same...
juliette.. what did u set in bios? there's a lot of things that can affect the overclock
check here www.i4memory.com :)
eva's there and he's got a wonderful guide with how to tweak for venice
