why sell them, would venice be able to do a lot better?
I had to pay for an FX-55
cause i got more than one CAA2C so sell some off to cash up for the new stuff around the corner :)
right now I have a winnie stable @ 2.9ghz with 1.8v that can bust out a 30sec superpi and a low 27min superpi 32m. System in sig. The memory controller is royally pissing me off though as it won't let my bh-5 go above 250mhz 1t, where it can do about 260mhz 2t.
Is it worth it for me (remember I have phase change, a Mach 1) to get this 3500+ even though I am going venice the day they hit stores? How much longer is it likely to be, and how much higher will I hit than the 2.9ghz of my winnie. Will my mach1 be able to handle the heat? And finally, will the memory controller let my bh5 go above 250mhz 1t?
That's a decent overclock already. If I were you, I'd wait for the Venice just because these CPUs are good for now, but from what we've seen the Venice will be even better.Quote:
Originally Posted by computerpro3
check this out: http://www.xtremesystems.org/forums/...ad.php?t=57765
3500+ caa2c @ 3.6ghz
How many have they're AS CAA2C 3500+ under cold with no problems. I've got a chilly 1 chiller coming soon and am prolly gonna run it -15f or lower.Quote:
Originally Posted by CyberOps
This 3500+'s are 130nm, so no cold bug :D Mine is coming in a few minutes =)Quote:
Originally Posted by chew*
Your CAA2C rocks hard .
Diogo , show here some screens
Cumps
Swapped back to my winnie ;)
Runs way cooler, about 9°C...
As u wish my friend =)Quote:
Originally Posted by |-jokker-|
Cooled by r404a Prometeia Mach I, tweaked by RickY:
http://pwp.netcabo.pt/orlandojdr/3355mhzs.jpg
http://pwp.netcabo.pt/orlandojdr/pi3200Mhzs.jpg
It's not maxed out yet, think 3400Mhzs SS is possible and 3230Mhzs for PI/3DMark. I think its good for a 269€ CPU =)=) At least it's better than my 3200+ Winnie that did 2800Mhzs on prommy :S
Btw anyone with prommy r404a? Post temperatures please.
Looks like 2.8 with 1.55v is about it for now, heat is an issue if I up the volts. I'm thinking about building a chilled liquid system. Almost have all the parts..... I'd like to get 3.0 out of it.
Btw anyone has a bug that makes the 180 Memory diviser @ multi 11 acts like 166 diviser? Like normaly 180 diviser should be CPU/12 @ multi 11 and 166 CPU/12, with this CPU 180 diviser is CPU/13 and Diviser 166 is CPU/14, but only in multi 11. Weird lol
I finally got mine to run at 2.6ghz@1.6v. I shaved off .1v! It had been running prime for about 20min when I left for work. I consider that promising, before it would fail prime instantly at anything less than 1.7v. I'll be home soon, hopefully it will still be running.
what's the production date of yours?
This looks like the right chip to delve into a64- land with, considering i have a decent watercooling setup to dampen what looks like a fairly high amount of heat. Close to 70C on water sounds almost silly/prescottish! :eek:
The FX-55 is a waste of money unless you have money to burn. Especially when there are good overclocking Athlon 64's available for a third of the cost. You wont be able to tell a difference in system performance. You'll get a few more points in benchmarks but my wallet is willing to sacrifice a few points in bungholiomark 2005.Quote:
Originally Posted by sauria
I would wait and get a 3200+ or 3500+ Venice core or whatever speeds are available at a good price. I'm sure they will overclock well.
It depends on how much voltage you have to use. I'm running 2.6Ghz w/ 1.55V now and i'm not breaking 55C in prime.Quote:
Originally Posted by Frodin
just ordered one of these to torture with phase change from ZZF; If it doesn't get 3ghz or 2.9 with a GOOD memory controller, I'll revert back to my 2.9ghz winnie.
I got another one the other day. Its a CAAZC 0422GPMW .. it wont even do 2450 on stock vcore. Piece of :banana::banana::banana::banana: .. :mad:
Any worse?
Hmm, an old reject?
clawhammers don't report temps right. notice that on a cold boot, temps in the bios will always be around 38-40c? ;)Quote:
mine caa2c 0505 APBW can do super pi at 2805 on 1.6v but can't prime even with higher voltage most stable at 2750 only
Can super pi 32m consider fully stable?
Complete stability (Prime, SuperPI, memtest) is the only "full stability"...
it is i have to prime blend test for 24 hours to consider full stabilityQuote:
Originally Posted by Ref
These 3500+ really ARE hot. The reading I get from mine is pretty accurate. With 2600Mhz and 1.75 I get 70c load. The copperbase on my watercooler is appr 50-55c.Quote:
Originally Posted by ozzimark
I believe _very_ few of members in here will make a statement based on a reading from BIOS, MBM5 speedfan etc. Everyone knows that these readings are often pure fiction.
Most will use their finger or a fluke for temp readings.
