Hi guys, got some trouble on my A7N8X (rev. 2.0) so I hope you can help me. The main problem is this board is kinda inconsequent. One time I can run a certain FSB (say 200 MHz) with 12 hrs of Prime 95 stable. Then, after some experimenting (e.g. raising the FSB to 205, unstable, set it back to 200 again), the board allready shows me an error on Prime95 after 15 minutes or so. The only thing changed was FSB, so I can't see why it would be stable one time, and fail pretty soon the next. I set my MP to 9 just to be safe, and know CPU speed is not the problem.
This is my 2nd A7N8X, and both have given me the same problems, although this one is slightly better I admit. Maybe it's some other hardware causing the trouble, but it just doens't make any sense.
My full specs:
Barton 2500+
1x 512MB HyperX PC3000 (known stable up to 200Mhz 2-5-2-2 @ 2.7V)
Asus A7N8X 2.0 (BIOS 1007)
Sapphire 9800np (currently non-overclocked)
SB Live! 1024 Player
IBM 180GXP 120GB
The CPU and chipset are watercooled, CPU temp is 46C/114.8F stressed, 40C/104F with case open (got a small case that gets up to 37C/98.6F when stressed for a long time).
Another thing I'm noticing is slight stutters in games at certain FSB speeds, I need to raise the AGP speed to up to 72Mhz to fix this. Anyone else experienced that?
Any ideas on why my board is stable one time, but fails pretty quickly the next? Getting kinda frustrated by this board :(
