a view on my front:
http://img505.imageshack.us/img505/9783/img3569sn9.jpg
it's a chieftec cs-601 red with 2 revoltek ultra red
a view on my front:
OMG!!!!!! thegooch, cable management!!! its hard in a p180, but its possible, i did an OK job you you can two!
Couple shots of my rig:
Asus P5W DH Deluxe 1707
Intel C2D e6400 L632A931 @ 3.2ghz 400x8 1.4275 vcore with Tuniq Tower 120
Thermalright HR-05 NB cooler
2 X 1 GB Crucial 10th Anniversary 400mhz 4-4-4-12
Sapphire X1950XT 256 MB
2 x 74 GB 10k Raptors RAID 0 HD
2 X 250 GB Maxtor HD
Samsung 18x DVD Burner with LightScribe
OCZ GameXstream 700w
Antec 900
How the Tuniq Tower fits with the HR-05 NB Cooler...and a nice shot of my 10th Anniversary :D :
http://img181.imageshack.us/img181/9862/img2608um8.jpg
Its a pretty close fit:
http://img130.imageshack.us/img130/7291/img2611yv7.jpg
Side shot with 120mm fan attached to side. The top corner actually had to be cut in order to fit with the TT120 because its so big:
http://img130.imageshack.us/img130/3927/img2630pn7.jpg
Inside shot. I'm usually taking out and changing my HD's a lot so I never really get around to managing those HD cables >< :
http://img149.imageshack.us/img149/5744/img2631vw0.jpg
ops double post
I think you have mounted your TT120 in the wrong direction.Quote:
Originally Posted by diction10
See why do people always say that? There is a reason why he installed it that way, 1. The HR-05 SLI and the Tuniq can only fit together by installing the Tuniq that way, and 2. There is a 20cm exhaust fan at the top of the case..Quote:
Originally Posted by SaII
so the Tuniq isn't installed wrong at all.
Had to. As you can see its already a tight fit next to the NB cooler, so I had to have it point up. Which isn't really that bad of a deal, because it blows up into the 200 mm fan on the top of the Antec 900.Quote:
EDIT - Shift you shifty man! He beat me to it and explained what I was going to, thanks man.
I think the HR-05 SLI may have fit in and still have the TT120 mounted the "preferred" wayQuote:
Originally Posted by Shift
It won't. Trust me I tried all different directions of bott the TT120 and the HR-05 and the way I have it is really the only way to easily make it work. Take a look at the pics and try and imagine the TT turned the correct way. The HR-05 can't sit straight if you put the TT120 on the right way...its forced to lean a little bit...which would obviously not be good for a heatsink.Quote:
He said the HR-05 SLi not the regular HR-05. The SLi version has offset fins, as shown in the pic.
Brendan
Some very nice PCs up here :D
:p thanks for the reminder!Quote:
Originally Posted by cyberspyder
^ Ahh well I don't have the SLI...just the regular 05 :p.
Very nice rigs :D @ SaII is that an antec 900?
Way to go! I guess the thermalright page was wrong then as P5W is listed as not-compatible:
http://www.thermalright.com/a_page/m...r05_lga775.htm
I may get one of those now, any idea if it would fit with Big Typhoon on? :confused:
http://i14.photobucket.com/albums/a3...01-07_2315.jpg
http://i14.photobucket.com/albums/a3...01-07_2120.jpg
@diction10: Whats your max FSB with and without the hr-05?
Hmm its hard to say about the Big Typhoon...it looks pretty wide, I'm not sure it will. Your best bet is to look at the first 2 pics I posted and try and estimate if you think it will fit.Quote:
Originally Posted by Malk4vi4n
And I actually never tested it with the stock cooler. When I was reading about the board alot of people were saying that the NB gets hot and limits overclocking, so when I bought the board I just got the HR-05 with it and since its not an easy thing to take off the stock NB cooler (because of the long heatpipe) I just went ahead and put it on right off the bat.
However I think it helps..my NB barely gets warm to the touch with it on...though the 120mm fan on the side of my case blows some air on it as well so I'm sure that helps.
Here's my air cooled rig. First picture is with my XFX 6500 Passive Videocard
http://img249.imageshack.us/img249/9413/dscn1912pl5.jpg
Second pic is with EVGA 7800 GTX
http://img249.imageshack.us/img249/3103/dscn1966eb8.jpg
nice cable manament :banana::banana::banana::banana:
here is my media pc.
http://i18.photobucket.com/albums/b1...-internals.jpg
Wow, thats very clean, really nice job on the wiring there:clap:Quote:
Originally Posted by lowfat
Here's my system:
http://img443.imageshack.us/img443/8732/stp61780qp1.jpg
this one looks cool because of the Camera's Orange LED
http://img260.imageshack.us/img260/3136/stp61781ld0.jpg
http://sean.nickfire.com/core2redux/IMG_1482.JPG
22c idle with 4ghz conroe @ 1.6v :D
Finally got some pics worth showing!!!! :banana:
http://i23.photobucket.com/albums/b3...r/IMGP0478.jpg
http://i23.photobucket.com/albums/b3...r/IMGP0485.jpg
http://i23.photobucket.com/albums/b3...r/IMGP0487.jpg
peace
OMG that uv light is soo niiice /\ /\
nice done, very clean
TheReds, one more uv maniac :D... btw nice Infinity.
