2*512 Kingston Value PC3200 BH5 "251we"
Anybody got ScreenShot from A64 tweaker settings to try? :)
U can try this :
http://img104.imageshack.us/img104/7088/timings6lj.jpg
Great Bandwith, Stability and Performane, but not all sticks will do that.
Pushing Set freeze the system. Sticks doesn`t like that Max Async Latency 9ns.
And with an other Max Async Latency it works? Can't set it below 9, or i get instant freeze, after Bios-screen. With my Neo2 it works with 6.0/4.0 ...
Yes, Max Async Latency 6ns-8ns works great. Now I´m testing with your settings example Max Async Latency is 6ns :)
Oh and mobo is Gigabyte K8NSU NF3.
K fine, good luck! :)
Hola Saaya. (Lo prometido es deuda :) )
2x256 KHX3200 339wf
http://img84.imageshack.us/img84/232/epsn05759kw.th.jpg
1mb Spi1mb:
265mhz 2-2-2-0 1T 3.23v
http://img84.imageshack.us/img84/469...51mb0jd.th.jpg
277mhz 2-2-2-0 1T 3.55v
http://img304.imageshack.us/img304/9...71mb0hx.th.jpg
282mhz 2-2-2-0 1T 3.66v
http://img304.imageshack.us/img304/7...21mb9jb.th.jpg
285mhz 2-2-2-0 1T 3.82v
http://img304.imageshack.us/img304/3...51mb6ey.th.jpg
Maxim stable 3.93v
Spi8mb:
280mhz 2-2-2-0 1T 3.71v
http://img304.imageshack.us/img304/9...ings0om.th.jpg
+ In process
Spi32mb:
In process...
Bye
Wow, nice 8M results!
Hi:
I purchased on Ebay 2x512 Corsair LLPT. This guy don´t know he was selling BH5 ^^. He tell me he did not OC never.
I remove heatspreader and this is:
307WE the two sticks
And I hit with 3.31v in memtest86 this:
- Module 1; 256 2-2-2-5
- Module 2; 260 2-2-2-5
But, when I put the two memory stick with the same voltaje (3.31) it only do 248 2-2-2-5
It´s posible???? :confused:
I´m with a MSI NEO2, with Vdimm@3.3v mod and a powerstream PSU. 3.31v with tester when memtest is runing.
Bios 1.8MOD.
Hello
My corsair 3500c2 v1.1 2x256 (2452D)
http://img526.imageshack.us/img526/1...7s1m9rk.th.jpg
Salu2
Nice time and checksum. ;)Quote:
Originally Posted by chikitano
Hello
There is no space for everything ;) I will post other pic after burning (with time and checksum)
Salu2
mm nice memos:)Quote:
OT: Todas llevan la misma semana? Seguro q no
Salu2
Hello
That also happens to meQuote:
Hi:
It´s posible????
Bios 1.8MOD.
V Stick1 Stick2 Dual
2.8 226 220 216
3.0 241 234 231
3.2 262 250 247
3.4 270 259 259
with the voltage it is solved
:D no, they are not the same week, of 4 faces, 3 are 245 and one is 246Quote:
mm nice memos
Salu2
PD: tengo unas mas chulas que estas...
Salu2
I expect seeing soon the nice ones, Chikitano ;)
DFI nF4 SLI-D, 3.73VDIMM, AIR cooled CPU&MEM -1'C :cool:
CORSAIR CMX256A-3500 C2
XMS3502v1.1
024704
Stick1:
Winbond
2452D
W942508BH-5
and same stepping on other side
Stick2:
Winbond
2452D
W942508BH-5
and the other side
Winbond
2462D
W942508BH-5
http://koti.mbnet.fi/dani69/DFI%20nF..._1.64V_AIR.gif
http://koti.mbnet.fi/dani69/DFI%20nF...s_1.7V_AIR.gif
Hello
Very good result Dani, they are equal that my, but yours they are quite better, although cold also help :D ...whereupon voltage you have obtained it?Quote:
XMS3502v1.1
024704
Stick1:
Winbond
2452D
W942508BH-5
Stick2:
Winbond
2452D
W942508BH-5
and the other side
Winbond
2462D
W942508BH-5
I also ;) .. because I am having more problems of the account :(Quote:
Salu2
Chiki.
.- (331we) 2-2-2-0 1T 3.63v 270mhz (Corsair3500C2 1.1v 256@nF4) Xevipiu
http://img463.imageshack.us/img463/9...tats3as.th.jpg
Stick1: 250/250we
Stick2: 331/332we
P.D: Ahora te miro de que semana era el otro juego de C2, ese hacia 283 2-2-2-0 3.82v, creo q eran 250we todos son caras
Salu2
Thanks M8 :)Quote:
Yes, 3.73V, I edited my post above;)
sayaa i have mushkin lvl 2 3500 bh-5 2 x 256
one is 313we and other is 338wf right now super pi 1m and 32m and all game stable and all benchmark stable and memtest stable
right now there at 250 fsb 2-2-2-5 @ 3.4v dual channel
2*512 MB Corsair PC3500 C2PT v1.1 BH-5 + DFI Lanparty nForce 4 SLI-DR
vDimm = 3.6V (set in BIOS)
Cooled by a 120mm Antec fan
DDR 545 2-2-2-7
2x512MB Kingston HyperX KHX3200AK2/1G (Winbond CH-5)
Week 51 Year 05
3.0V - 224.3 MHz 2-2-2-5 Dual Channel
3.0V - 265.4 MHz 2.5-3-3-8 Dual Channel
BH-5:
342WF - 261MHz 2-0-0-5 Dual Channel, 3.7V
Screen: http://files.upl.silentwhisper.net/upload4/26.454s.JPG (Does do as much as 270MHz, but I don't have any screenshot)
342WF - 280MHz 2-2-2-5 Single (One stick), 3.8V
Screenie: http://files.upl.silentwhisper.net/upload0/280.JPG (I eventually had enough after about three hours of memtest, so I simply shut it down. Rock solid, even though it was done on an Asrock-mobo)
week 22
"322wf" 2.0-2-2 3.4v 265mhz (xms 3500 2x256@nf2)
Original alpha timings
DDR DUAL CHANNEL ENABLED.
Nf7 rev 2.0 & xp-m
week 22
"322wf" 2.0-2-2 3.71v 260mhz (xms 3500 2x256@nf2)
2-2-2-2
alpha 0 0 3 3 3 0 3
Corsair 3200LL 303WE 264MHz @ 3.5v 277@3.85v Neo2 nForce3
I'm sure it would do higher with nf4
