Originally Posted by SAE
Mate, the sb vdd gave me nothing but problems. As it did for LORD. I don't recommend it.
Did ya see the smaller sinks between all those bigger ones on my board!? These are attached to the driver ICs that can get scorching hot. Cooling those may help some, I did not try without ocp though.
OCP is done replacing the smds through other smds or ordinary fixed metal film resistors. The resistors onboard are 2.2k, I'd say 3.3k to 4.7k should do you good ;)
The problem with the original 5-5 was, it could not stand a cmos clear with bh-5 inserted. You had to take it out replacing it with some stuff able to do cas3.
