great setup B Gates !!!
Very nice test rig...trip SanDisk Xtreme IIs, I expected nothing less...lol
Interesting....we both run RST 11.2. ;)
it doesnt matter 11 or 12 series orom the both work the same as far as performance goes
see this B Gates that happens to me since ages
2x ADATA SX900 256GB RAID0 128k stripe free space 349GB
RST 12.7
http://i.imgur.com/4ZNeqju.jpg
UNINSTALLED REBOOTED
http://i.imgur.com/RPCp5Xo.jpg
but i still see this on devices
http://i.imgur.com/pnivpao.jpg
not sure if i should install 11.2 RST---will try and post what it gives
Great job Bill, been waiting to see how you did with them. Now I got to resist picking up a z87 mobo, dam. Thanks again bud... :clap:
the first benchmark shows that write caching is not enabled look at the 4k write compared to the second bench. I'm not sure if the iastorF affects anything but it has been my experience that it does not. Uninstall 12.7 and install 11.2 https://downloadcenter.intel.com/Det...?DwnldID=21408
use the exe so you have the rst control panel
look at the system report in rst control panel.
did you see this article? http://www.rwlabs.com/article.php?id=836
yes i already repetead this procedure since ages :) look
with RST 11.2
http://i.imgur.com/8ErDyrn.jpg
http://i.imgur.com/qjmiLye.jpg
see those files are version 12.7 im kinda scared to remove them by hand...
I see what you mean. can you look in RST control panel at system report? it looks like this:
http://i876.photobucket.com/albums/a...ps7d8b595c.png
its also varies now increased...
RST 11.2
http://i.imgur.com/p0VIIkj.jpg
this is what u want
http://i.imgur.com/3WZLLIe.jpg
seems all ok right ?
yes seems perfect. I think device manager is wrong.
btw this is my system
http://i.imgur.com/P6KERWx.jpg
According to my knwledge I suspect, that B Gates and not andressergio's Device Manager is wrong.Quote:
Originally Posted by B Gates
@ andressergio:
Your Device Manager pictures show a typical issue, which may happen, when the user is downgrading from any Intel RST(e) drivers v11.5 or higher (containing an additional SCSI filter driver iaStorF.sys) to any "classical" Intel RST driver using just the iaStor.sys.
Bug: The iaStorF entries of the Registry will not be deleted by the uninstall procedure.
Bad consequence: The performance will drop, because the absolutely unneeded SCSI filter driver iaStorF.sys is still active.
For more informations you may read the "Switching from RST to RST(e) driversand vice versa" chapter within the start post of >this< thread. There you will find a link to the solution of the problem as well.
My experience is that even though Ive never used RST(e) I still have have iastorf:
http://i876.photobucket.com/albums/a...ps371ac048.png
http://i876.photobucket.com/albums/a...ps89b7c5c4.png
And I have used your procedure to remove it, which resulted in zero performance gain. I thoroughly tested to see if there was a difference and there was not. The thing is iastorf is there whether or not you have ever used an RST(e) driver. I have not.
Look at the rst control panel:
http://i876.photobucket.com/albums/a...psa13c5f11.png
I believe this is correct. I apologize if I'm misunderstanding you.
Thanks Fernando and B Gates for the great help, i read your post Fernando but it send me to a link saying the same, i actually downgraded from 12.7 to 11.2 and YES i have that problem, so what i should do ? uninstall 11.2 then let windows use the native ones and delete files manually from both windows and registry ?
andressergio definitively had used the Intel RST(e) drivers, before he "downgraded" to the RST driver v11.2.0.1006.
Furthermore there are big differences regarding iaStorF between Windows 7 and Windows 8. Win8 doesn't use the SCSI filter driver iaStorF.sys at all, even if you install any of the RST(e) drivers.
Reason: Win8 and Win8.1 do support the UNMAP command, whereas Win7 doesn't do it. The TRIM in RAID0 feature requires the UNMAP command to let TRIM pass the Intel SATA RAID Controller into the RAIDed SSDs.
