Well I've two 7970 in CF and the only problem I had past 12.4 was low performance in Crysis 2 in some areas, nothing related with trixx overclock, AB overclocking, or Asus tweakit overclocking. Though I know this softwares are not forgranted because as I sad they don't come from AMD but else from various partners to operate my cards out of spec.
I've been using 12.11 beta 1, then beta 3 and now beta 4 flawlessly with my cards overclocked to 1240/1550 using AB, 12.11 Beta and 12.10 ( I think ) both fixe the Crysis performance problem. I'm using Windows 8 Pro 64bits which I reckon ins't standard software at the moment, despite AMD drivers do work well, 12.11 gave me a performance boost and I can overclock with both AB and ASUS TweakiT, didn't care to try trixx sinse I find it inferior due to not having memory voltage increses.
The only graphic card related problem I have are sporadic freezes when opening GPU-Z those I find are software related.
All in all quit bashing AMD because your favorite 3rd party software doesn't work, look under your own system, maybe a windows clean install could help. Clean the resgestry completly prior the installation of new drivers and enjoy.
